King of Tone - PCB design problem?
Started by norim_13, July 20, 2012, 11:30:57 AM
norim_13
Hi!
After building  few DIY pedals with PCB bought from others, I decided I should try to make my own designs and start etching.
As King of Tone was in the list of my favourite pedals, and I happened to have the schematic, I decided this would be my first PCB (now I regret this decision... I should have tried something easier...)
I designed the board, etched it, bought the components, assembled everything and... the pedal just hums...
I checked some points of the pcb with my multimeter (only conductivity, and some spots I know that are supposed to "have" 9v), and everything seems fine. About the components, I don't know what to test... The IC (NJM4580) is probably fried (I mounted it backwards at the begining), but I've already tried with a similar one (RC4558) that has the same pinout, and still no sound.
After all this, I think the problem must be in my design, so I'm asking for help about this. Is there anyone who can tell me what's wrong here:
(sorry for the huge image, but I think it's better to check the circuit)
In the PCB are not shown the DIP switches and trim pots because DIY Layout Creator doesn't support them... I think you know where they are supposed to be ;)
The schematics I used are from Madbean (Aristocrat project). Can I post the schematics here? (I read something about some schematics not being allowed to be posted...)
At the moment I'm testing the circuit with only in and out jacks, and all ground wires connected in a breadboard (no 3PDT, no LEDs, no battery snap, and only the first stage of the circuit (Side 1) and jacks).
Thanks for reading all this. I will appreciate any help.
João Norim ;)
I haven't checked it all, but there are some mistakes that will stop it working.
D7 is the wrong way round, if you are getting 9 volts after this then you must have built it the correct way round.
You are missing R12 and C11 (your R12 is in the R13 position) this means your VB voltage is wrong, this will stop it working
R2 is connected wrong, it should go from pin 3 of IC1 to the VB trace, you have it the wrong side of C1.
The schematic is here for anyone else http://www.madbeanpedals.com/projects/Aristocrat/index.html
norim_13
Tyvm.
I'll check all of that tonight.
About D7, I  got that wrong, but as I checked there was a problem there, I bypassed it to have 9v at the IC.
Thanks again. iI'll leave here some news later ;)
Regards
norim_13
Hi!
Fortunately, I have sound coming out of the pedal! Thank you very much slacker, I'm closer to get this done.
Although I have sound, it's not perfect, in fact it's awful... It's highly distorted, and seems like my fuzz factory with max compression and stab...
I don't have C8 (1uF polyester capacitor) connected. Can it be the problem?
Best regards
João Norim
norim_13
#4
Btw, slacker already gave the link, but here are schematics:
<Sorry, was asked to remove this link.>
bean
Quote from: norim_13 on July 20, 2012, 05:11:28 PM
Hi!
Best regards
João Norim
Check to make sure you are getting 4.5v on the VB supply. Sounds like you ICs are not biasing correctly. C8 has nothing to do with that.
In fact, leave C8 and C19 off altogether and just use 1uF film caps for C9 and C20. Also, 47n for C1 and C12 is a big improvement, IMO.
norim_13
I think the problem must be there...
I measured that, and I think I got about 9.4v from the PSA, and ~9.2v in VB... I have to recheck that. It should be a problem in R12, right?
João Norim
bean
You do not have a second 47k (R13) on PCB1 to create the voltage divider which makes VB. That's the problem.
norim_13
I added R13 after slacker told me it was missing... But I'll recheck that. The problem must be somewhere in VB circuit...
norim_13
I checked, and I have 9.4v from DC, and 5.2v in VB.
Shouldn't it work like this?
norim_13
#10
As my hope for this PCB is gone, I've already started working in a new one.
By now I already have 1 channel completed (only missing the VB section, and pin 8 connection to 9v).
Can somebody check if everything's ok here:
Thanks and best regards
João Norim
That looks almost correct to me.
You have a connection from pin 7 of the opamp to VB, that shouldn't be there.
I think the switch is wrong, it should connect D2 and D3 to pin 7 of the opamp. It should connect D5 and D6 to VB, it looks like you have it connecting both sets of diodes to pin 7.
norim_13
You're right. I connected the top left switch pin to both, pin 7 of IC and VB. It should only go to VB.
Later I'll upload the complete new layout.
Regards
João Norim
norim_13
#13
Just finished the new layout. Just need somebody to check this one, and I'll give KOT another chance :P
Here it is:
João Norim
EDIT: Again, DIP switches and Trim pots are not in the layout because are not available in DIY Layout Creator.
norim_13
I tried a new layout: 3PDTs, Volume and Tone Pots and Jacks onboard. The only components which will have to be wired are gain pots and DC Jack.
(in the layout is missing a jumper between 9v and one of the ICs pin 8, and also Input jack conection to ground ).
Could you please verify this? I'am ready to etch, but this time I prefer that someone checks it before to avoid mistakes as in the last time...
Here is the layout:
GodSaveMetal
Quote from: norim_13 on July 25, 2012, 12:51:46 PM
Here is the layout:
OHHHH! mine I have loking for these!!! is it cheked??? thanks man; I´ve TUNED on these!!
Isakajr
Hi Guys, I`m willing to try this. Can you supply the PCB for transfer?
norim_13
Hi!
I will test the layout as soon as possible. Just waiting for some parts to arrive...
If it works fine, I'll send for anyone who's interested ;)
Best regards
João Norim
Isakajr
Cool João. I`m waiting some of those odd diodes too..
