A gain stage example to help with biasing transistors
Started by Gus, December 01, 2013, 11:17:59 AM
Gus
Here is a gain stage sim screenshot
Two different transistors often used in effects and different supply voltages
The resistor values used are standard fixed values and were selected for a stable bias with changing supply voltage
As often with a circuit like this the parts selection is a compromise.  The input resistance is on the low side, just looking at it you should see it is under 47K
with C1 and R6 removed the gain is under 5
Does the schematic help?
discuss
LucifersTrip
I always like to see the hfe to collector voltage chart,  so I have an idea where increasing/decreasing hfe makes very little change to the collector voltage.
(ie, what's the sim with hfe 50 and hfe 800)
always think outside the box
Gus
Some more biasing examples
Gus
I am bumping this because I think it is helpful
Note  the Q2 collector voltages
How they change with supply voltage
How they change with different beta Hfe
compare to the other bias methods
Gus
a bump because I saw some bias questions and another sim screenshot
jafo
Could you expound a bit on how R7 does its thing? Is it limiting current to B? Adding input impedance?
I know that mojo in electronics comes from design, but JFETs make me wonder...
antonis
Quote from: jafo on October 26, 2021, 01:55:43 PM
It just puts itself in denominator place of NFB gain formula.. :icon_wink:
