u-boat wiring?
Started by bifbangpow, January 19, 2017, 10:45:45 PM
bifbangpow
I'm building the th effects versionof the U-Boat suboctave pedal, and the build instructions doesnt include wiring or even a full photo of the build.  I used this standard wiring diagram to attempt to wire it up  : http://www.madbeanpedals.com/tutorials/downloads/StandardWiring_MBP.pdf  but the project I'm building uses on board pots so I'm a little confused.  Here's the project: http://diy.thcustom.com/shop/u-boat-v1-1-pcb/
Whatever I did didn't work and I'm hoping I can get some wiring guidance.
Keep on keepn on.
blackieNYC
Maybe this will help.  I figure since you don't reference his site, maybe you don't know- the u-boat was designed, I believe, by MerlinB aka The Valve Wizard
http://valvewizard.co.uk/uboat.html
merlinb
bifbangpow
Quote from: merlinb on January 20, 2017, 06:05:04 AM
Yes i referenced that link in my post.  That is how I wired my pedal but it's not working.
Keep on keepn on.
bifbangpow
Quote from: blackieNYC on January 20, 2017, 12:15:28 AM
Yes but I used the printed circuit board from TH Effects in Germany, and their layour is a little different.  Slightly different components too.
Keep on keepn on.
merlinb
Quote from: bifbangpow on January 20, 2017, 01:27:42 PM
Then you have made a mistake. Look carefully.
I've built a few U-Boats (incredible circuit Merlin, big fan of your work) using the TH Custom board and used the wiring Merlin posted. I can confirm that's how it's supposed to be. If you have it wired like that and it still isn't working that's when we would start asking for pictures of your board and voltages on IC pins.
bifbangpow
Quote from: vigilante397 on January 20, 2017, 08:51:32 PM
Ugh. It's been awhile since I couldnt find the problem on a circuit.  Just need someone elses eye on this thing.  Heres a photo:
and
hope that helps.
Keep on keepn on.
thermionix
What's it doing/not doing?
bifbangpow
Quote from: thermionix on January 21, 2017, 04:58:51 PM
No sound clean or otherwise.  The led lights up briefly when i push the stomp switch but only if I hold the stomp switch down.  The second my foot is off the stomp switch the led stops working  So I think there must be a short somewhere.
Keep on keepn on.
thermionix
That sounds more like a bad switch.  Yours looks okay, not melted from overheating, but have you checked it with a continuity tester?
Cozybuilder
BBP- I don't see any wiring errors, the diodes, electros and chips look like they're oriented properly- I agree with thermionix that it sounds like a bad switch.
bifbangpow
Quote from: thermionix on January 21, 2017, 05:41:32 PM
You guys were right. It was a bad switch.  Switched it out and now I at least get clean sound.  No Effect yet but thats probably just a cold joint.
Keep on keepn on.
bifbangpow
If Im getting clean sound but nothing when the effect is on, is there a particular wire I should check the joints on?  I'm having trouble finding it.
Keep on keepn on.
Cozybuilder
You should double check that the PCB is not shorting out on the pot bodies first- were the component leads trimmed short on the solder side? It looks like your soldering skills are good, so eliminate the easy stuff first.
thermionix
Quote from: bifbangpow on January 21, 2017, 08:18:50 PM
You get 'clean' as in bypass, then no sound when you hit the switch?
Power?  LED lighting up?
bifbangpow
Quote from: Cozybuilder on January 21, 2017, 08:58:18 PM
Yeah I've got small peices of foam tape between the pots and the board.
and thanks for saying my soldering skills are good heh
Keep on keepn on.
bifbangpow
Quote from: thermionix on January 21, 2017, 09:45:46 PM
Yes. LED and power is good.
Keep on keepn on.
1. Audio probe.
2. Debugging thread.
jimilee
Quote from: bluebunny on January 22, 2017, 10:57:25 AM
1. Audio probe.
+1
Sent from my iPhone using Tapatalk
