Brian May treble booster
Started by Chris S, November 15, 2003, 09:36:10 PM
Chris S
Has any built the Brian May treble booster on R.G's site? and what transistor did you use?
Mine seems to be cutting more treble than boosting at the moement?
Chris
bettycat
BC182L
Try to find NOS ones with the metal can head, they sound very different from the Fairchild remake (plastic head), available from Mouser
Chris S
Any ideas where I could get one?
Chris S
did a net search to no avail...
gtrmac
Small Bear has selected Germaniums that work very well. I've built two so far and they sound great.
bettycat
Quote from: gtrmacSmall Bear has selected Germaniums that work very well. I've built two so far and they sound great.
BC182L´s are silicium transistors, not germaniums.
Chris S
Hi Gtrmac,
I assume you built two Brian May boosters, which of small bear's germanium transitors did you use?
Chris
gtrmac
I'm sorry, I built two Rangemaster clones. These use germaniums. I got two unmarked transistors from Small Bear and I also have three Hitachi's that I haven't tried yet.
smallbearelec
For the germanium boosts like the RM, I can still provide generic NOS U.S.-made unbranded stock with gains from 60 to 100 or so--depends on how "hot" a pedal you want. $3.75 for gains under 80, $4.50 for 80 and over.
The Brian May boost is biased differently from the RM. According to the NTE cross-ref, the BC182L is NPN silicon with an Hfe in the range of 80-300. I guess there's a certain combination of gain and internal capacitance that makes the device sing, and the modern re-makes don't have it.
I am sending to Bettycat (today) some older plastic-case BC182L that are National Semi from before the Fairchild takeover. I can get more of them if they turn out to have the mojo. I will fish for "real" metal-can BC182L for next year's stock list.
Based on gain spec, maybe a 2N2222A or one of my NOS Fairchild 2N3565 would work. Also, if someone has a sample of the metal-can BC182L, I could ask for a quote on getting a "work-alike" done.
Regards
SD
Chris S
Chris S
Gulp... time to eat humble pie  :oops: - sometimes I hate being a begginer.
I had the transisitor in backwards... now pedal sounds much better, will add a volume control at the end of the cuircit. I'm still kenn to find out what the pedal will sound like with a better transistor though.
(If any one else builds one please let me know if the origonl hand drawn schematic is wrong about th wiring of the transistor)
Many thanks!
Chris
Ge_Whiz
QuoteI had the transisitor in backwards...
Hah! Been there, done that. About three weeks ago, following 35 year's experience.  :lol:
