Yet Another HMP!
Started by RDV, November 10, 2004, 08:51:05 PM
RDV
An honest opinion from A. Hermida made me reconsider what I've been doing with this thing. I'd lost site of what I was trying to do in the first place, which was build a DIY Heavy Metal Pedal. What got me started on the BMP style tone control was the fact that as I turned down the Rat style one I was using, it lost volume, which I didn't like. I turned to the BMP style with it's volume recovery section when what I really needed was just the volume recovery section.
This one is a true Heavy Metal Pedal. The previous versions sound like warm fuzzy overdrives, but not this one. It's not versatile, it just kicks ass. Sound samples coming soon. The lite version will be posted soon also.
"Turn it up loud Captain"
RDV
RDV
Light simply means no parametric section.
RDV
MartyMart
Ricky, once again nice work !
Was about to start a HMP V3, but will have a try this, still trying to get a layout on perf to work/be neat...... any tips ??
Cheers,
Marty.
Alpha579
once again, nicely done, looks great...
Alex Fiddes
Marcos - Munky
Cool!!! Waiting to hear the soundclips.
RDV
Quote from: MartyMartRicky, once again nice work !
The 5 is very tight and Metallica sounding. The parametric also is much more effective without the BMP style tone control. This one is really not too hard on perf as no wire really cross over. What I do with an IC based project is use a board that has two rails down the center that I make the 9v & Vr supply. That makes it so easy cause the opamps straddle this and you work on either side depending on which channel of the OA you're wiring up. The perfboard looks like this:
RDV
LiquidSteel
hi
great work ... now i can chose between the rev4 and rev5 with a switch :)
RDV
Quote from: LiquidSteelgreat work ... now i can chose between the rev4 and rev5 with a switch :)
Have you got that worked out? Cause that would be very cool! You could use the same 100k pot as the BMP uses if the cap to ground is changed to a .0022uF.
RDV
kusi
hi
maybe so?
http://forum.musikding.de/attachements/HMP.jpg
use a small 3dpd-switch (i don`t konw how they named...), 2 stages of the switch for the treble-pot, an 1 stage for a higher Inupt-capacitor (adds a 10nF  paralell to the 15nF = ~25nf)
grettings from switzerland!
kusi
edit: ups, i forgot the 15k R to ground in the BMP-tonestack... :oops:
MartyMart
Thanks Ricky, that makes sense of it !
V-cool,
Marty. 8)
LiquidSteel
hi
kusi ... you changed in your chematic some values ... does it sound better than the rev4 ??
kusi
hi liquid steel!
the values are from the REV3. better sounding? i`dont know, i didn`d finish the pedal...... :D
btw. in REV3 is the R to ground 22k, not 15k.
mfg kusi
RDV
In versions 3 & 4, the values of the Bigg Muff style tone control can be played with to do what you want it to do. Download Duncan's Tonestack Calculator and play with the values till you see something you think you'd like, that's what I did.
RDV
Peter Snowberg
Right on RDV! 8) 8) 8)
I've gotta build one of your designs one of these days. :D
Eschew paradigm obfuscation
kusi
hi rdv!
now, i finishd my HMP, with the two tonestacks. but the new tonestack with the 10k/2,2n didn`t work well.  i can`t hear any changes in the sound.... :?
maybe a litle, when i turn the turn the Q-trimmpot....
but the BMP-tonestack sounds very good :twisted:  great pedal!
can you help me? thanks
kusi :)
RDV
Quote from: kusihi rdv!
kusi :)
The 10k/22n is just a fizz control to shave off the extreme high end. You can try different cap values to change the frequency that it affects. Post your findings!
Glad you like it.
RDV
kusi
hi rdv
i thought, that this is a treble-control... how it works by your pedal?
should i in- or decrease the capacitor?
greetz
kusi
kusi
greetz
kusi
you know, tone-control  like the proCo rat....
RDV
It is like the Rat tone control. You could try the rat values, or just increase the size of the cap.
RDV
RDV
Try a .022uF and see how you like it.
RDV
