Completely pre-drilled copper boards?
Started by ExpAnonColin, December 19, 2004, 02:12:47 PM
ExpAnonColin
Is there any way to get copper boards that already have holes drilled in them all over, sort of like a perfboard covered with copper on one side instead of nothing or just pad-per-holes?  That way you could just draw in the trace and you wouldn't have to drill any holes...  What would this be called for googling?
-Colin
Gilles C
The closer thing to that is a stripboard.
When I add jumpers, I see them as components.
Gilles
ExpAnonColin
Quote from: Gilles CThe closer thing to that is a stripboard.
Gilles
Can you really etch stripboard like that?  It would be interesting...  sort of a pain.
Are you sure they don't make anything at all like this?
-Colin
puretube
hey Colin: a super idea!!!!!!!!!!!!!!!
the only minor drawback/difficulty for the DIY etcher would be proper alignment of the (photocopied or whatever) layout exactly fitting the holes.
[btw: you ever seen those machines drilling/pressing those holes @ a rate of hundreds at a time through a stack of 5 PCBs?]
the other fear would be under-etching the pre-drilled pads, but with proper developing/etching, you could get over that...
I don`t think this has been done yet (at least for DIY, afaik...) - I`ll try to get in contact with people/companies related to this...
Thank you for this great idea!   8)  8)  8)
ExpAnonColin
Quote from: puretubehey Colin: a super idea!!!!!!!!!!!!!!!
Sorry I didn't see your reply until now.  I can't wait to hear more about this!  I was thinking more along the lines of just using a pen...  or, I'm sure if you designed your own PCBs it wouldn't be super hard to set up your PCB software to autodraw up the holes or something.
-Colin
toneman
U can't etch plated strip pcbs.
Only copper strip pcbs.
puretube
"plated" ?
imagine: plain copper-layered PCB, like the ones you normally use for etching
- but then:
already have holes (preferably 0.8mm) drilled in there, in 2.54mm distances...
now go, paint your traces on it (lines between the holes..., pads around the holes) with a etch/waterproof pen.
or have the "Colinboard" presensitized for photographic transfer...
jrc4558
Hey!
Take a piece of predrilled, put it ontop of not predrilled, secure them together to prevent sliding and... drill away!!!
puretube
I did use such masks (jigs?) for drilling since a couple of decades ago...
but now we`re tired of drilling!
:P
gez
Paul Perry (Frostwave)
Oh no Gez, you just gave me a truly awful vision.. SMT stripboard! The horror, the horror :shock:  :x  :cry:
NaBo
i personally love the idea.  i drew and etched 7 boards a month ago, and that part was easy.  now, just to drill, i had to find a 1/32" bit for dad's dremel (only found that as part of a 15$ set, no doubt)... only to find that it wouldnt lock in either of the little tip things he has... so theres another search and expense on my horizon.  so here i am waiting for boxing day, when, if there were pre-drilled copper clad boards, i would have probably built 7 circuits by now.
probably not a good idea to use exclusively, in the long-run, but could easily beat perfing in my books.  much easier.  of course, you have the added danger of more horizontal etching around the holes, eating away at your pads... but i doubt that would be a serious problem when using some of the quick-etching methods i've seen described while searching through this forum.  great idea, hope someone can put it out there some day.
zeta55
Here's what i've done in the past.
I used singlesided copperboard, printed the layout on plain paper. Then I glued the paper on the board with a water based gluestick. Drilled the holes, peel the paper of cleaned the board and used a good permanent ink pencil to draw the traces.
Visit my site: http://www.zeta-sound.se/
gez
Quote from: Paul Perry (Frostwave)Oh no Gez, you just gave me a truly awful vision.. SMT stripboard! The horror, the horror :shock:  :x  :cry:
I think there is something like that Paul ('SMT Prototype Board'?) It has common shapes for ICs and traces running here and there.  You just link it up and use a different board if there aren't enough/the right pads to make the circuit (it seems a bit haphazard to me)...the nightmare begins!  :twisted:
ExpAnonColin
Somehow my post from last night got completely deleted.  Oh well.
Quote from: zeta55Here's what i've done in the past.
That's not too bad of an idea, but you still have to drill :(
-Colin
puretube
zeta: done that many times in the past (cellotape on 4 sides - easier peel of...),
but have to agree with Colin, again!
David
Colin:
I hesitate to chime in on a subject that I don't know too much about, but perhaps this might lead to something good.  Check out the thread on using conductive ink.  Perhaps using that with non-pad per hole perfboard would get you what you want.  At any rate, it should make for some very interesting experimentation!
I don't understand your hesitation about PCBs, though.
Peter Snowberg
Eschew paradigm obfuscation
ExpAnonColin
Quote from: DavidColin:
Drilling is tedious, that's all.
-Colin
NaBo
very.  i bought the little attachment that i needed to use the 1/32" bit with the dremel yesterday... another $20.
oh well, i have some pretty decent boards now RTS... it'll be easier than perfing im sure, but damn, its much more expensive and time-consuming to make and drill boards from normal copper-clad.
im still totally on board with this idea.  let's make it happen, people!  :D
