uses for tubes other than amplifying....
Started by casey, March 17, 2005, 02:18:49 PM
casey
here's a strange question:
i think i remember hearing or reading somewhere that you can run an audio signal through a vacuum tube, and create distortion..what i mean is that the tube would not even have power to it.....almost acting like a diode or something of that effect...?
so the tube would just act like a non-powered "dead" component...
can this be done?
Casey Campbell
ESPguitar
If so it would have been cool.. But i don't think it will work very well..
RB
casey
Quote from: ESPguitarIf so it would have been cool.. But i don't think it will work very well..
RB
i dunno....it would be interesting to experiment with these types of things....i would inject the signal in an unorhodox way....  if that makes sense... :roll:  maybe with a strong signal from a 386 chip.
Casey Campbell
Connoisseur of Distortion
i STILL think that if we tried some of those tubes that came with a triode and a set of diodes as a clipper, we could have a sweet Electra distortion  :D
casey
Quote from: Connoisseur of Distortioni STILL think that if we tried some of those tubes that came with a triode and a set of diodes as a clipper, we could have a sweet Electra distortion  :D
would it be possible though to use an unpowered tube as the clipper?
Casey Campbell
Dirk_Hendrik
The Fender performer 1000 works on this principle where the 2 halves of a 12ax7 are connected as diodes. However, there is a small DC current to get the tubes into conduction. Signal voltage  only is not going to work.
More stuff, less fear, less  hassle and less censoring? How 'bout it??. To discuss what YOU want to discuss instead of what others decide for you. It's possible...
But not at diystompboxes.com...... regrettably
casey
Quote from: Dirk_HendrikThe Fender performer 1000 works on this principle where the 2 halves of a 12ax7 are connected as diodes. However, there is a small DC current to get the tubes into conduction. Signal voltage  only is not going to work.
uh huh, here we go....  now this is where im going....what about some type of diy stompbox with this principle in mind?
Casey Campbell
casey
also - i dont really care about the tube necessarily other than a different type of clipping...something uncanny maybe.
Casey Campbell
aaronkessman
wouldnt you still need a filament power supply?
also, an example of a non-signal-amplifying tube may be in fender trem circuits.
Gladmarr
If you look at www.metasonix.com or search for tube synthesizers and Eric Barbour, you'll find some pretty interesting audio uses for tubes.  Though I think this isn't really what you were getting at....
casey
Quote from: aaronkessmanwouldnt you still need a filament power supply?
yup, that's the question....    do you?
Casey Campbell
Paul Marossy
By design, tubes will not do anything unless the "correct" voltage is being applied to the filament(s). If no voltage is applied to the filament(s), no heat, no current - nothing happens...
EDIT- Try reading this page: http://www.vacuumtubes.net/How_Vacuum_Tubes_Work.htm
cd
You can use a tube as a clipper, like with a diode.  Take this into account though, a tube is going to cost you $5-12, not to mention the socket and power supply required to run it.  A diode costs 10 cents.  What would you rather work with?
casey
Quote from: cdYou can use a tube as a clipper, like with a diode.  Take this into account though, a tube is going to cost you $5-12, not to mention the socket and power supply required to run it.  A diode costs 10 cents.  What would you rather work with?
i know, im just wanting to experiment for the fun of it.....and to see if i can get a different type of clipping than what a diode can achieve.
Casey Campbell
SaBer
What is the second half of the first tube exactly doing in this schematic?
I can't see anything else, than the signal coming from the first half, connected to the plate and grid...
There are 10 kinds of people in this world. Those who understand binary and those who don't.
zachary vex
Quote from: SaBerWhat is the second half of the first tube exactly doing in this schematic?
it's forming a rectifier (plate and grid are shorted).  rectifiers in compressor/limiters are usually used to accumulate a DC voltage (from the input signal level) that's used to control the output level.
