Want more depth from your EA Tremolo easy?
Started by Processaurus, April 11, 2005, 12:04:34 AM
Processaurus
Found an easy way to give the EA a little more cajones.  Just put another FET in parallel with the one thats there acting as a variable resistor (Q2 on the run off groove schematic: (http://runoffgroove.com/eatremolo.html)
Just solder each corrosponding leg together, like hook the gate to the old FET's gate, source to source, and drain to drain.
Since the FET acts as a variable resistor, and two identical resistors in parallel amount to half the resistance of each, the idea was 2 fets in parallel would have a lower resistance when on, making the main transistor amplify more on the tremolo peaks.  This makes for a louder output on the peaks, so you turn the volume down, the valleys are quieter, ie: more depth.
The overall circuit gain is doublish now, which may possibly cause the circuit to clip, depending on how hot the guitar signal is.  There's no clipping with when I tested it with a strat, but I'd be interested and grateful if anyone knows how to lower the gain, besides attenuating the input (BTW I made the GGG "improved" version, with the JFET input buffer and the 2n3904 doing the tremolo, rather than the ROG Mosfet version).
Anyway, this is a good tweak, for tweakers.  One could maybe even put 3 or 4 fets in parallel for super deep trem, if you had a way to lower the overall gain.
Another thought on this effect is the rate pot being reverse log 100k makes a much nicer sweep than a linear pot, where its nothing, nothing, and then woah, all of a sudden all the action is in one small area of the pot.
sean k
One way is to use negative feedback either a resistor from the collector to the base,biggish(something I made had two 220k's in series with a .001n cap to ground on the junction which would effectively lower the gain with negative feedback but leave a small treble boost),or,I made one of these a few days ago,but can't remember if it has a cap on the emitter resistor...duh,of course it has...for the trem so that won't work.Maybe a voltage divider somewhere before the 2N3094.
Monkey see, monkey do.
Http://artyone.bolgtown.co.nz/
onboard
Cool! 8)  The EA Trem. It's not your Father's tremolo.
Seriously though, parallel jfets - would that be the same as choosing a jfet with 1/2 the Vgs that you were using,  or am I not getting that?
-Ryan
"Bound to cover just a little more ground..."
Paul Perry (Frostwave)
Quote from: onboardCool! 8)  The EA Trem. It's not your Father's tremolo.
It probably IS your father's trem, if you look at the date on the original article :D
Putting fets in parallel?? anything could happen, seeing how wide a range the characteristics vary over.
Ge_Whiz
I used a 2N5457 in mine, and it already goes full-depth at the top end of the depth control. FET variation, again.
