Anyone have a 1.5 Henry (1500mH) wah type inductor?
Started by analogmike, May 31, 2005, 02:30:19 PM
analogmike
HI,
I got an acoustic 360 amp head (with fuzztone!) on ebay but the inductor in the Vari-Amp circuit is dead. It is a chocolate 03 wah type inductor but 1.5Henry instead of 500mH as in a wah. It is used to cut or boost the selected frequency, the vari amp selector selects between 5 capacitors to choose the frequency.
Anyone have one of these inductors, maybe a pullout from an old organ or something?
THANKS!
DIY has unpleasant realities, such as that an operating soldering iron has two ends differing markedly in the degree of comfort with which they can be grasped. - J. Smith
mike  ~^v^~ aNaLoG.MaN ~^v^~   vintage guitar effects
http://www.analogman.com
rocker-D82
Why you doesn't build it??
http://www.smallbearelec.com/Detail.bok?no=368
There is a link to an "how to" in the description page. I think you can obtain what you want in this way.
analogmike
Very cool!
But I doubt it could get up to 1.5H, and no time to work on my own stuff.  Have you ever seen the shoemaker's shoes?
aron
Can we put 3 wah inductors in series? You know, I need this value as well for a midrange circuit I want.
Eb7+9
Hi Mike,
... take a look at the Cinemag CM-2312 1.2Hy Pot core audio inductor - Pultek Eq. replacement ... you can add a 300mH coil in series to make it exactly 1.5Hy ...
http://www.cinemag.biz/inductors/inductors.html
... also, Mesa-Boogie uses some high value coils in some amps and Ampeg might also might have some old stock lying around if you know anybody working there ...
(I just saw Aron's post)
... adding three 500mH coils in series should work too ...
~jc
Hal
Quote from: aronCan we put 3 wah inductors in series? You know, I need this value as well for a midrange circuit I want.
wah inductors are so overpriced.
analogmike
Quote from: Eb7+9Hi Mike,
~jc
Will ask Cinemag about it.
Doh- I tried 2 wah inductors but in PARALLEL, I was thinking capacitors... it did sound OK with 500mH or 250mH but the low range was weak.
analogmike
Cinemag got back to me, they can make some 1.5H ones for about $20 each in low quantity. Anyone else want some?
Ardric
What's the inductance of a typical single coil guitar pickup?  Would that be a workable substitution?
aron
Dan N
I have some 1H pulls from organs. They are Brown TDK in the 2 leg fasel looking package. Add a 500mh and you have your value. Free if you want to give it a try.
Manolo Dudes
I've "converted" recently a Dunlop Jimi Hendrix Crybaby into a Clyde clone (see details here) and look what I found when I measured the inductance of the original inductor:
:wink: I suspect it's a defective unit... the JH wah sounded abysmally ugly  :roll:
a.k.a. "Calambres" in www.pisotones.com
aron
hmmm I guess all we need is this Mouser inductor?
42TL024
I believe I've used it before ... possibly in the Torres midrange kit.
I will get a few and try it out.
Thanks Puretube!
aron
