Introducing: the Super ReFurb.
Started by PCS, June 22, 2005, 04:15:18 PM
PCS
This is a Boost/OD/EQ pedal based on Blackface Fender specs. The first two fets are in a configuration based on the Super Reverb preamp gain stages, and the last is loosely based on the single 6L6 power amp from the Champ. Loud, brassy, gritty and Fendery, this sounds pretty tubey for three transistors. Pics of my build are coming. It would make my day if somebody actually built the first circuit I designed. I've built it, so I promise it works!
PCS
Notes: The bright switch is optional; I left it off mine because it's pretty bright already (and I ran out of room). I subbed Q2 for a 2N5458, giving a little more grit to my ears.
