Octave Divider layout?
Started by SonicVI, July 22, 2005, 02:04:13 PM
SonicVI
Anyone have a layout for a good octave divider such as the Mutron, Boss OC-2, etc...?
SonicVI
Nevermind, I should've just searched :)
StephenGiles
Are they good? I have my doubts.
Stephen
hank reynolds 3rd
The MutronOctaver layout i did (i think it's hosted at munky's site) works fine...The Stability Switch doesn't seem to do that much ,But its wired in correctly...I'm also In the process of adding the cicada (an oct up circuit) to mine as the ringer is good but not that decent an oct up....I've also seperated the straight/Oct down signals to there own pots.....
The only difference on my layout is the 220ks near the 4011 ic...They weren't on all the schems i had ,so my build has them omitted....Not sure if they do that much, the oct down is pretty stable and the Tone control helps smooth things out (a little bit fuzzy on the highest treble setting)...
Enjoy
Sam
SonicVI
Quote from: hank reynolds 3rdThe MutronOctaver layout i did (i think it's hosted at munky's site) works fine...The Stability Switch doesn't seem to do that much ,But its wired in correctly...
I had a Mu-tron abou ten years ago (bought and sold it for $100, yeah and doh!) and the stability switch didn't seem to do anything on the original either.
Daniel
SonicVI
Do you have a link for Munky's site? I'm kinda new here.
thanks,
Daniel
Marcos - Munky
Link to the Mutron layout:
Copy and paste both links in another window.
geocities.com/munkydiy/mubd1.jpg
geocities.com/munkydiy/mubd2.jpg
