Electric Warrior
finally settled on a set of transistors ;D :
Magnus
Hello,
Quotethose look so neat!! congratz!
Thank you  :)
Quotedid you use OC75s for your MKI clone or did you use replacement such as AC125 / 126 / 128 ? (and if you used OC75s, did you try any other Ge transistors?)
Q1 is a OC70 (my OC75's don't have the right hFe-values), Q2 and Q2 are AC125's,
I tried AC128's too but the AC125's really sound better for me...
@ Electric Warrior:
Great one!
Greetings
Magnus
AMZ Booster, Dist. +, DOD 250,
Dr. Boogey, Fuzz Face's, JCM800-Emu, LPB1,
May Booster, Obsidian, Orange T/B-Booster,
Pentaboost, Prof. Tweed, Rangemaster's,
SansAmp GT2, Superfly (Amp), Guv'nor,
Tone Bender MKI/MKII/MKIII, TS 808
tuckster
Jorge: great first post :)
Is it just me or do you guys notice too that the builds are getting cleaner and more professional every day?  :icon_biggrin:
Very nice pictures!
Barcode80
Quote from: Pigyboy on September 26, 2011, 12:34:58 PM
Here is one for Slade!  Ask him to translate  ;D
Op Amp driving a Ge transistor with switchable diodes
What's the purpose of the zip tie that's on the power jack  ???
tasos
I was going to ask too!
Lol! ;D
Frances Rhodes
Quote from: Magnus on September 26, 2011, 01:36:52 PM
ok, thanks.
i also found that AC151s were a cross match for OC75s, but they are quite expensive and i can't find selected ones, and i'm not sure i want to buy a hundred of them just for 1 clone!
by the way, what Hfe should Q1 be? i looked everywhere i could but it's the only information that i couldn't find out about!
cheers
"If it's too loud, you're not too old, it's Alancka Effectors."
https://www.facebook.com/alancka.effectors?sk=info
Pigyboy
Quote from: Barcode80 on September 26, 2011, 02:07:53 PM
It is holding the battery clip wires so if it gets tugged it doesn't pull at the connections  :icon_wink:
And you'll have to admit, I'll be rich as shit
I'll just sit and grin, the money will roll right in....
                                                            - FANG
Pollinator95
Is the graphic what the name implies? In any case, bravo.  :icon_eek:
Edit: Grease / dirt?  ;D
WARNING: I AM A NOOB
Magnus
Hello,
50 - 70  ;)
Greetings
Magnus
Barcode80
Quote from: Pigyboy on September 26, 2011, 02:18:30 PM
I can't see where that zip tie even touches the battery cable... ?
I'm talking about the one around the threads on the DC jack...
Frances Rhodes
Quote from: Magnus on September 26, 2011, 03:17:09 PM
Hello,
50 - 70  ;)
Greetings
Magnus
thanks a lot!  ;D
Pigyboy
Quote from: Pollinator95 on September 26, 2011, 02:51:09 PM
Yes, the graphic is what the name implies.  :icon_lol:
Grasa - Fat(without the diode clipping) & Mugre - Dirt(with the diodes)
Quote from: Barcode80 on September 26, 2011, 03:35:46 PM
You can't really see it in the picture but the red/black twisted pair is anchored to the dc jack with the zip tie
                                                            - FANG
Hides-His-Eyes
Quote from: bbf3 on September 24, 2011, 06:17:40 PM
a Tube Screamer TS808 (Ruined Machine)
Best live band I've ever seen. :)
arawn
I'm just trying to figure how eggs and father have anything to do with a pedal, course it could be my very rudimentary spanish
"Consistency is the Hobgoblin of Small Minds!"
Gus Smalley clean boost, Whisker biscuit, Professor Tweed, Ruby w/bassman Mods, Dan Armstrong Orange Squeezer, Zvex SHO, ROG Mayqueen, Fetzer Valve, ROG UNO, LPB1, Blue Magic
tiges_ tendres
Quote from: arawn on September 26, 2011, 05:23:32 PM
Eggs usually refer to ones testicles.  I always thought Jefe, meant boss. El Boludo isn't that an arsehole?
Try a little tenderness.
Slade
#17575
I'll PM my address ;)
BTW, "caña" here in Chile is also used for "Hangover".
Quote from: tiges_ tendres on September 26, 2011, 06:15:14 PM
You're absolutely right!
Jefe: Boss, chief.
Boludo (argentinian term): Stupid, idiot, etc.
Slade
I tried to go Magnus with this one... but how could I... Didn't take enough Magnusin pills.
Anyway, it's a A/B Loop selector with master bypass and A+B Switch (Guitar->Loop A -> Loop B - > Amp). Not the most beautiful pedal I've made but the paint gave me a lot of work. Here it is:
Cheers!
Fernando.-
nexekho
Quote from: Slade on September 28, 2011, 11:40:21 AM
How do you guys get the wiring so neat?  I get that you're very careful to cut to the perfect length, but even so my wiring tends to slowly round out over time until it becomes unsightly.  Does it have some coating or a large core?
I made the transistor angry.
John Lyons
Very Nice Fernando!! I like the colorfulness.  :icon_biggrin:
Basic Audio Pedals
www.basicaudio.net/
Barcode80
Quote from: nexekho on September 28, 2011, 11:45:23 AM
Solid Core wiring stays pretty good. I switched to solid core a year or two ago and haven't gone back to stranded since. everyone says stranded is less prone to breaking, but i've found the opposite in my builds...
