Recommend a Blues Driver type build and a Country compressor
Started by rosssurf, May 30, 2006, 09:02:54 PM
rosssurf
I have a friend who is interested in having me make him a Overdrive pedal and a good country compressor. By country I mean for country music. Can anyone recommend a good compressor and overdrive for his application.
He has the Boss  Blues driver and likes it alot. Is there something similar that I could build.
I would consider any project but I must admit I am fairly new to this so a Veroboard layout is best for me.
markm
Now you're talkin' MY music!!
Being a country Telecaster picker,
I like the Dyna-Comp, the Ross Comp, Orange Squeezer is useful though it has more of a "in your face"
tone and feel to me.
I built the Flatline and like it and currently I have a Q&D on the bench.
I used to strictly use the Dyna but as of late, I have grown to like the Ross Comp from TonePad built
with no mods at all.
I know this doesn't help much but, Country and Compression go hand in hand.
Besides, there doesn't seem like there are alot of C&W fans here!
Here's a Country Compressor for ya cowboy!!
rosssurf
I specifically remember seeing your Round-up compressor. That is beautifull. I built the flatline but It does not seem to do much. It turns out to be a nice booster but I really can hear any increse in sustain. I am in the process of doing the Ross.
Do you recomend an overdrive as well?
Thanks for responding!
rosssurf
Oh! MarkM! one more thing my buddy uses the Boss CS- somthin', he doesn't rememberwhich version. He is not real crazy about it. Is the Ross compressor a different feel? Perhaps better for country?
markm
I think alot of guys like the CS-2 comp....I had one and it went the way of e-bay!
I didn't like it but, for a country player a comp is a real personal thing.
It either fits you or it doesn't......kinda like a woman!!
The Dynacomp was the country standard for many moons but, Keeley kind of opened
everyone's eyes to the Ross comp.
I had a Keeley and dumped that one on ebay too but, I got a free T-Shirt from him!!
I think the Dynacomp or Ross is the key.
Build 'em stock they sound fine.
For a bit of grit in the mix, either the Peppermill or Dragonfly's Sparkle Boost.
     MarkM
joedudeman
I love the Texas Longhorn on the pedal.  I am a bit biased as I do attend U. of Texas.
-Joe
Gilles C
I may not be a Country fan, but I am getting interested in Country Blues these days, if that makes you feel better...  :icon_mrgreen:
The reason is that I just got a double DVD from Jim Weider, and he sounds d*** good. He uses tremolo a lot, and he mentioned the Echoplex once...
The fact that I also began to develop an interest in the Echoplex last week also helps.
Btw, I have a Boss CS-3, but don't really use it. Maybe that I should try building one with more character...
Gilles
MartyMart
Quote from: rosssurf on May 30, 2006, 10:00:59 PM
There must be a problem with the flatline build, I have made two now amd both work
very well.
I would check over it and in particular the LED/LDR wiring.
For a very good range of OD, from clean boost to crunch, try Mark Hammers "The Crank"
That's a hell of a pedal, would be great for Country "slight crunch" tones.
MM.
rosssurf
I will look into " The Crank"
as for my Flatline I used a Vactrol  vtl5c3 I got from Small bear. Would an LED/ LDR combo be better?
MartyMart
Quote from: rosssurf on May 31, 2006, 10:52:06 AM
Perhaps, I dont know the specs off hand for that vactrol but the circuit just said "LED/LDR" so I went with a
$2.50 small bear LDR and red 3mm LED wrapped in heat shrink.
I get a good range from light comp to VERY SQUISHED and a ton of volume boost available if needed.
Sustain is nice at about half way, perhaps worth you having a "tinker" with ?
MM.
markm
Supposed to be a VTL5C2 I think.
That could be a problem.
rosssurf
http://aronnelson.com/gallery/bcreekmur/flatline_compressor?full=1 Here a c3 was used. I have tried mesuring the resisitance in full dark mode but I am not an octopus and have a tuff time doing it. I will rig something up.  Should I get measurements in silence and with a strum?..is this correct ?Do I just use a DMM across the led or the ldr?
MartyMart
Did you make sure that the "LED" side of the vactrol was the correct way round ?
There should be a "dot" on one side which shows the cathode -->l  side ....
MM
rosssurf
Yes it seems so. I have the led side closest to the diodes and up top where it is shown
rosssurf
It seems my resisitance is 98K weather I am strumming or not. Maybe a bad Vactrol. If I was to make an led/ldr combo does it matter what sort of brightness the led has? Any particular color? I know I need a ldr that changes alot from light to dark.
MartyMart
Mine was a "standard" 3mm red LED, end slightly flattened with a small file, polished a bit otherwise
it was a "milky white" end, then super glued to the LDR and wrapped in heat shrink.
I'm not sure if an "ultra bright white" would be better or worse !
I've made several of them, including the ones for my Easy Vibe and they all worked very well.
They are the common red ones as used in Boss pedals
MM.
The sidechain on the CS-2 and the Dynacomp/Ross are virtually identical, with the CS-2 using a higher-quality OTA chip and accompanying input stages.  The so-called (and misattributed) "Hammer mod" to the Ross for variable/preset recovery times is actually taken from the CS-2.  I'm not denying that unit-to-unit variation would result in a pedal that person X sees as sounding better for country than another, but the differences in how they "feel" are generally not gonna be that huge OR consistently occurring.  In many instances, I imagine between-pedal differences are going to be easily altered by very simple mods.
rosssurf
