Black Cat OD / Freddy fuzz vero layout
Started by Xavier, July 03, 2006, 05:47:42 AM
Xavier
I hope everything is correct , please let me know if there's any error and I will correct it. I've been always curious about this one. Can I use any other IC? I haven't got any OP275 available.
Isn't it great this layout software?
Torchy
You need trace cuts under R9, C4, C6, C8.
MartyMart
Vol1 and Vol3 connections also need reversing.
Vol 1 lug at output is always "ground"
Vol 3 lug is output from circuit
Vol 2 lug is connection to switch/output jack
Otherwise, nice little layout
MM.
Xavier
Done, thanks for the corrections !!!
Next will be the Zombie chorus, If I'm able to..........
dimebagslash123
o sound a pain but what is ment by reversing vol 1 and 3? and the info about 2? im building this pedal and decided to scrap pcb and build out of board but not sure what needs changing from the picture, thanks in advance, also anyone know how to get op275 in uk? and where in uk is best for housing? iv got a cheap component store
