Can't get diy layout creator to print
Started by zab, August 09, 2006, 09:17:13 AM
zab
 hi to all this is my first post and i hope someone can help i have loaded the diy layout creator on to my computer and it does all it should other than print. When i press the print icon it looks as though my printer is recieving data as normal but after the sheet has passed through it is blank also when i press print pnp a message comes up that says cannot convert  OleStr to Boolean if you have had this problem and have been able to rectify it please could you reply. My computer is running XP and my printer is a Samsung Izzi laser thanks Zab:icon_sad:
Seljer
If you can't print it export the image of the PCB and print it in some other program (I think its at 200dpi)
