Buffering Buffoon
Started by zpyder, August 15, 2006, 05:23:41 PM
zpyder
Sometimes for an object or an idea there's a term that is simultaneously informative and elusive.  They can sometimes lead to very silly questions, like:
What is the purpose of a buffer?  I've seen that boosters (simple amps) can be used as buffers... but, why?  What for?  What do you get from a "buffer" and how is it different from a simple amp?
thanks
zpyder
www.mattrabe.com/ultraterrestrial Ultraterrestrial - Just doing our little part to make new rock go where it should have gone in the late-90's, instead of the bullshit you hear on the radio today.
Pushtone
Check out the short bit of text "What do buffers do" at the bottom of this page
http://www.generalguitargadgets.com/index.php?option=content&task=view&id=69&Itemid=100
This sums up why I needed a buffer in my signal chain.
Then there this one...
http://www.petecornish.co.uk/case_against_true_bypass.html
And this one... FAQ #3 about half way down page
http://www.customaudioelectronics.com/frequently_asked_questions.htm
Like all things in life, you need to find a balance between buffered and true bypass.
Pushtone
Another name for a buffer:
Unity Gain Pre-amp
phaeton
The buffering part is understandable, but why don't they make "true bypass" Bayer? ???
Stark Raving Mad Scientist
Thomas P.
#4
in most cases (maybe all) they're use to match certain impedances and they are no different from a simple amp if you mean basic (non-)inv amplifier as they all alter the output impedance in respect to the input. sometimes we don't want any gain added so we use a unity gain amplifier aka buffer (as one of the fellow answerers already said).the need is simple: low ohmic source but the need of a long shielded cable, etc.
god said...
∇ ⋅ D = ρ
∇ x E = - ∂B/∂t
∇ ⋅ B = 0
∇ x H = ∂D/∂t + j
...and then there was light
zpyder
Satch12879
Buffers do NOT match impedances; they bridge impedances.  If you were to match the input impedance of one device to the output of the other - meaning making input equal output - you'd get a 50% reduction in level due to voltage divider action.
At their most basic, a buffer presents a sufficiently high impedance load to whatever source you choose to drive it with.  The rule of thumb is that "high" is approximately 10x larger and that is the minimum.  And it's done to minimize or eliminate these kind of loading effects.
While simple buffers do also offer low(er) output impedances, it does NOT mean they have the capability to drive every load, or the ability to deliver the appropriate current that the load requires.  Single transistor buffers are a prime example.
Repeat: low output impedance does NOT mean high drive capability.
Further, "unity gain" is a squirrely concept, depending on whether you are talking balanced or unbalanced lines.
Please see these two Rane Application Notes, possibly the two MOST informative technical documents on audio electronics design I've come across:
Unity Gain and Impedance Matching: Strange Bedfellows
Practical Line Driving Current Requirements
Passive sucks.
Progressive Sound, Ltd.
progressivesoundltd@yahoo.com
The purpose of a buffer is to make impedance differences NOT matter.
bluesdevil
Quote from: R.G. on August 15, 2006, 06:37:53 PM
Thank you!!
"I like the box caps because when I'm done populating the board it looks like a little city....and I'm the Mayor!" - armdnrdy
