Johan's LA-Light compressor samples
Started by sverige_cruz, November 24, 2006, 10:01:44 PM
sverige_cruz
Hey everyone. Here are a couple samples of my build for this pedal. There's a limit (100) for each of the downloads so if it's reached and someone wants to host either, go for it.
It's a bit of overhead mic'd drums played by a friend of mine. I ran the sample with varying amounts of compression, and I think I have the name set accordingly. I remember someone mentioning that the switch changes the ratio at 1:3 or 1:10. Playing bass through it, I found the sound to be more subtle.
Here they are:
samples_comp.mp3
http://www.yousendit.com/download/OgfNAo4vUTl5TA%3D%3D
samples_limit.mp3
http://www.yousendit.com/download/OgfNAhlAz4N5TA%3D%3D
And here are some thread links in case anyone wants to read up:
http://www.diystompboxes.com/smfforum/index.php?topic=51105.0
http://www.diystompboxes.com/smfforum/index.php?topic=51282.0
http://www.diystompboxes.com/smfforum/index.php?topic=37090.0
http://www.diystompboxes.com/smfforum/index.php?topic=43721.0
http://www.diystompboxes.com/smfforum/index.php?topic=51101.0
Många tackar, Johan!
-- Jesus
edit: each sample starts off with the original clip and follows with 4 additional clips ranging from max effect to less...
KerryF
really wasnt expecting it to be drums... but anyway, I will host it for you in the sound clip section in the layout gallery with yours name.
sverige_cruz
Yeah, too bad I didn't have a guitar or bass track laying about. Since I had that drum track though, I figured it'd be better than nothing. I might have to pull out my bass and run it through and record. That'd be really cool though, if you want to set it up in the gallery.
-- Jesus
KerryF
Heres the hosted clips.  For some reason it adds my name because I uploaded them, but I put that you recorded them.  ;)
http://aronnelson.com/gallery/album72/LA_Light_Comp (Compression)
http://aronnelson.com/gallery/album72/LA_Light_Limit (Limit)
Kerry
BTW, if you record more, I will put those up too.
sverige_cruz
Hey Kerry, Thanks! Got some quickie-takes for you... me on bass. Little rusty, as I don't play regularly (although I probably should if I want to get any better...  :icon_rolleyes:)
Same routine as the drum tracks...
http://www.yousendit.com/download/OgdyWjTHp3l5TA%3D%3D
http://www.yousendit.com/download/OgdyWi8%2FBId5TA%3D%3D
I think I like the 3rd variation the best, or maybe the last one, for each take. I guess it can be cool to get that "There's a Riot Goin' On" sound sometimes. I'm sure it would sound different too, going thru a different bass. Mine's a P-Bass with flatwounds (as you can hear) and Fralins, going through an Acoustic 360 clone. Enjoy!
-- Jesus
