Suggestions for auto-wah, modulating wah??
Started by snoof, December 06, 2006, 10:06:49 AM
snoof
Looking for sugestions for a not-too-difficult auto-wah/modulating wah.  Similar idea to a trem, but wah instead; in that you set the rate of the automatic "wah-wahing".  The Boss auto-wah has a setting like this if I remember right.  Any suggestions?? ???
Scott
IIRC, isn't the ROG Phozer a modulated bandpass filter?
snoof
I checked that one out, but I was looking for a "wah" sound as opposed to a phaser though.  The clips sounded like a phaser to me.
ke4unr
http://www.generalguitargadgets.com/index.php?%20option=content&task=view&id=138&Itemid=153
Maybe the DOD 440 Envelope Filter clone at GGG?
Not a true "auto wah", but check out the sound clip and see if that's what you're after.
This one is on my list to build.
Ray K.
zeta55
Maybe this on http://members.shaw.ca/roma/wah-two.html  check out the running wah at the bottom of the page.
/Krister
Visit my site: http://www.zeta-sound.se/
snoof
The DOD is more of Mutron III auto wah effect (envelope follower).  If my terminology is correct here, I'm looking for a LFO modulated Crybaby ckt with adjustable speed kinda thang :)  I guess my use of "auto-wah" is not technically correct.  I meant "automatic wah", as in it's being automaticaly wahed for you.
snoof
Quote from: zeta55 on December 06, 2006, 04:24:27 PM
/Krister
Yes, this is the kinda thing i'm after.  Thnxs!  I think I heard a clip somewhere that was using the "idiot wah" ckt, modulated  by something??
mdh
Quote from: snoof on December 06, 2006, 04:31:36 PM
The original ROG Phozer was Tim Escobedo's Idiot Wah modulated by an LFO (I believe the one from the EA Tremolo). The schematic is still on runoffgroove.com, IIRC, but I think the link to it in the Phozer 2 article is broken. I seem to remember that I successfully guessed the filename after a few attempts, but I don't remember exactly what it was.
snoof
yep. I saw that as well, and the link takes you to homewrecker, but the phozer isn't listed...
snoof
#9
aha!  I found the clip I was referring to on this page (idiot wah)
http://www.home-wrecker.com/salvo.html
and the schem here...
http://www.geocities.com/tpe123/folkurban/fuzz/snippets.html
how would one implement the LDR talked about in the description??  I've never worked with any modulation type effects before :icon_redface:
Edit:  found the old version of the phozer from archive.org  http://web.archive.org/web/20040603163912/www.runoffgroove.com/phozer.html
mdh
Go to Geofex and read R.G.'s article on wah pedals (in the FX Technology section). That should clarify things a bit. The photon filter isn't exactly what you're looking for in and of itself. You would still need an LFO to vary the resistance of the LDR, thus modulating the wah.
BTW, the old phozer schematic is available on runoffgroove.com, but the filename is simply "phozer.png," not "old-phozer.png."
Meanderthal
 Many moons ago I had an old Ibanez script logo phaser- one knob. At the time I didn't like it much because it sounded just like a wah. I wanted it to sound like a PHASER! Anyway, if anyone know what I'm talking about and has a schematic for it, that might be what you're after...
boogietube
There's a Mutron Autowah new in the very first Layouts Gallery page
Pedals Built- Morley ABC Box, Fultone A/B Box, DIY Stompboxes True Bypass box, GGG Drop in Wah, AMZ Mosfet Boost, ROG Flipster, ROG Tonemender, Tonepad Big Muff Pi.
On the bench:  Rebote 2.5,  Dr Boogie, TS808
moosapotamus
Quote from: snoof on December 06, 2006, 05:20:13 PM
Take a look at the Tremulus Lune. The LFO drives an LED. If you want to use it to drive the Photon Filter, don't bother with the input and output sections. Lune LFO + Photon Filter = :icon_idea:
~ Charlie
moosapotamus.net
The MXR Auto-Q is essentially an MXR Envelope Filter with a few bells and whistles, one of them being the capacity to mix on-board LFO control and envelope control.  It's actually a pretty neat pedal that I wouldn't mind owning if my money didn't have to go other places.  The new Guyatone Ultron pedal, reviewed in the current newsstand issue of Guitar Player is also a modulated Mutron-type pedal.  You may want to try out one or both of these at a stiore to have a better sense of what features you like or aspects you like.  My guess is that whatever you end up with as a DIY pedal, you will not be able to use a single canned PCB layout/project, so best to have a keener sense of what you want this to be able to do.
Paul Marossy
I like Tim Escobedo's "Phuncgnosis". It's an auto-wah type thing. :icon_cool:
snoof
Quote from: Mark Hammer on December 07, 2006, 02:01:09 PM
I've got a Q-Tron, so I've got the traditional envelope-filter sounds covered so I don't need that sound.  I used to own a Boss AW-2, and that had a setting where you could set the speed of a continuously cycling wah,(footless wah) and that's what I'm after.  It looks like I have some good ideas from the posts above, I just need to implement them into something that sounds descent...
snoof
Quote from: moosapotamus on December 07, 2006, 01:49:24 PM
~ Charlie
Very nice schem!!  I like how the sections are defined.  Thanks man!
I don't mean to pimp my own design and it might be a more complicated than you were looking for but my slackfilter does exactly what you want.
It's a filter with envelope or LFO control and can do LFO driven wah type sounds.
Have a look at this thread for more information
http://www.diystompboxes.com/smfforum/index.php?topic=45148.0
searoad
