Mini-Boogie
Started by Rafa, January 23, 2007, 03:51:43 PM
Rafa
I would like to know if anybody has built or has some info about this project. 12ax7 with only 30V  ???.
What mods would make it sound good?
http://www.diystompboxes.com/smfforum/index.php?topic=18366.0
Cheers
Rafa
Cliff Schecht
12AX7's don't need more than 6.3V@300mA or 12.6V@150mA to get the heaters going... Nothing wrong there. Just remember, having tubes doesn't automatically make something sound good.
JimRayden
Quote from: Cliff Schecht on January 23, 2007, 06:14:17 PM
There is another factor called the 'B+' that does also contribute to the sound.
Jimbo
MartyMart
If I were you, I'd skip ALL the "starved plate" stuff, get an EH transformer from aron and
use proper B+ voltages   :D
Lots of fun to be had, just watch VERY carefully what you're doing .....
MM.
frickecello
Quote from: MartyMart on January 23, 2007, 06:51:55 PM
MM.
Yeah try this one, it features voltages around 300 V, you can use one of those small toroidal trannies, Ive built it and it sounds beatiful it uses 3 valves:
www.paginasprodigy.com/guitardoc/nicegirlharddriver.wmf
Cliff Schecht
Quote from: JimRayden on January 23, 2007, 06:46:15 PM
Jimbo
I figured I was missing something. I still haven't done any real studying on tube design so I'm definetly not the expert here :D.
Rafa
QuoteInsert Quote
You mean intead of using 30V to use lets say 250V.
thats sounds good but will the sound change much?
Ive read good reviews of this pedal at harmony-central
Cheers
Rafa
aron
Of the Mini-Boogie?
Interesting.
JonFrum
Quote from: Rafa on January 24, 2007, 07:53:36 AM
QuoteInsert Quote
Cheers
Rafa
Most people who have tried it say that the starved plate design is not the way to go. Plate voltage doesn't matter much when you're up in standard range - although 50V  does matter in some circuits - but when you take it as low as 30V you're really out of anything you could call a sweet spot.
aron
OTOH, there's a lot of development that could go on with these lower voltage tube pedals that I'd like to see. There's still something neat about using the tubes. How about those small tubes that Alfonso and others are using?
Johan
you can get good sound out of tubes at low voltage. the problem with most designes are that they are just high voltage circuits run at low voltage...an 12ax7 in a standard marshall or fender circuit disapates about 0.5-1watt. with 100k plate-resitors and running at 9-25volt, you're nowhere near that. also, at low voltage spacecharge start to happen. if that is not taken care of, things get even worse...just measure the voltage on the grid when running a standard circuit at too low voltage...it goes negative... :icon_eek:    easiest way to deal with this is to connect the gridresistor to supply as in the Tubedriver or to use a biaspot as in Aron's Shacka-tube...
...perhaps starved tube distortion could be something for the monthly-contest thingy?...
johan
DON'T PANIC
Rafa
I made a mistake the real name is not mini-boogie its mini-boogee.
QuoteInsert Quote
Cheers
Rafa
"Good sound" will depend on what you are after.  The higher the B+, the more headroom and dynamics.  If what you want is the sound of tube preamp distortion, then 30V (or less, even) may give you what you desire.  If you are after bright sparkly clean tone that lets a Tele bridge pickup sound different than a Les Paul bridge pickup, then you likely want much higher B+ voltage.  They both have their charm, but different people want different sounds.
aron
Rafa,
Can you give me a link? BTW: I own the device in question.
aron
hmmm those reviews are not too good!
puretube
Rafa
I can see theres a problem aparently there are two models the audio matrix and the mini matrix the one I read was this one:
http://reviews.harmony-central.com/reviews/Effects/product/Mini-Boogee/Audio+Matrix/10/1
