9v Electric Mistress Layout
Started by rasco22862, February 15, 2007, 12:26:18 PM
rasco22862
Hi, i´m trying to build this 9v electric mistress (NOT THE DELUXE ONE). I´ve search in tonepad, but there is no layout only the schematic, and in the ggg site, there is only the deluxe one. Does anybody know about a layout i could use??
Thank you very much
rasco22862
In the bill of materials of the pdf (9V_Mistress_project_file_v11_update.pdf), what are the Polar section? caps? what is 33u?
mudmen
Quote from: rasco22862 on February 15, 2007, 10:01:30 PM
Here's my guess: :)
Polar caps = polarized capacitors
33u = 33uF
David Gilmour :: Gear Forum
http://www.davidgilmour.pq.pl
rasco22862
Quote from: mudmen on February 16, 2007, 04:30:41 AM
Here's my guess: :)
33u = 33uF
Ok, thanks, i just was confused:p:p:p
rasco22862
Why there is two V+? I mean, i know that the layout says that one is for the battery and one for power supply, i mean are they connected??
analog kid
I've built 4 of these from that schem. I spent countless hours of "r+d"/experimenting on this one in my flanger obsession , along with my prized handbuilt A/DA's.    Don't connect those V+'s  IF you're really trying to build this.   best off for you to not even try to understand the BattV+ (charge) section and just use the  PS V+ for all power and just implement standard dc jack ps/batt switching
  Good luck , this isn't just a paint by number and fire it up crkt really.  there's a good bit of tweaking involved.   although sure if you're careful and put everything where it should be it will at least "work"
See the man with the stage fright, just standing up there to give it all his might..
rasco22862
so what is for the V+ battery ??
markusw
Quoteuse the  PS V+ for all power and just implement standard dc jack ps/batt switching
Use the PS+ for battery or power supply.
Markus
rasco22862
thanks i will, but just wanna know what is for the V+ battery?? :P
rasco22862
Any explanation of what does it mean the V+ Battery?
markusw
Quote from: rasco22862 on April 29, 2007, 08:52:39 PM
As far as I know in the original unit the tonepad schem is derived from the 2k7 resistor is shorted by the the DC jack if no PS is plucked in. I really don't have an idea why this switching schem was used.
Anyway, I included this option. Therefore, there are two pads in the layout one for PS V+ and one for Battery V+.
You can of course use the original switching schem but I believe that all builds including mine just used the PS V+ for both, battery and PS.
Markus
