Source for Box Capacitors (North America)
Started by boyersdad, February 22, 2007, 06:32:20 PM
boyersdad
Just wondering where y'all are getting the box caps, what you generally pay for them, and what the "official" name for them are. They don't seem to have them at my local shop.
Does Small Bear sell them?
I like amps etc.
calculating_infinity
Hey,
    I just made a large order on Mouser which included some boxed caps.  I bought a bunch of "AVX Multi-Layered Film Caps"  and "EPCOS Metallized Polyester Film Capacitors" (exact names).  For the AVX caps, I ordered 63V and the prices ranged from $.07-$.012 for most sizes.  I bought a couple 1uF caps for about $.44.  I also have some WIMA boxed caps that I really love but they are just too expensive $.30 and up.
    Steve from Smallbear stated that they will be offering WIMA boxed caps in the near future.  I would buy WIMA caps from Smallbear even at higher prices just to support someone who supports us.  Anyways hope this helps and if you want I can get you the mouser part numbers.
-Jonathan
boyersdad
That'd be great! What are the quantities required for $.07-$.012 per cap?
I like amps etc.
Hey there is no minimum order on the AVX Multi-Layered Film Caps.  I'm not sure which values you want but if you search mouser for ["AVX Multi-Layer Film Capacitors" 63v 5%] then you can sort out through them.  Heres a couple to get you started.  Always check the datasheets to see if its what you want (especially size-wise).  You can change out the tolerance and voltage if they dont have a certain value.
.1uf : BQ014D0104J
.001uF: BQ014D0103J
Need More? (copied, pasted, and cleaned up from part of my Mouser order.)
BQ014D0104J-- AVX Multi-Layer Film Capacitors
63V 0.1uF 5%
BQ074D0105J-- AVX Multi-Layer Film Capacitors
63V 1.0uf 5%
BQ014D0224J-- AVX Multi-Layer Film Capacitors
63V 0.22uF 5%
BQ014D0222J-- AVX Multi-Layer Film Capacitors
2200PF 63V 10%
BQ014D0472K-- AVX Multi-Layer Film Capacitors
63V 4700pF 10%
BQ014D0332J-- AVX Multi-Layer Film Capacitors
63V 3300pF 5%
BQ014D0102J-- AVX Multi-Layer Film Capacitors
63V 1000pF 5%
BQ014D0103J-- AVX Multi-Layer Film Capacitors
63V 10000pF 5%
BQ014D0392J-- AVX Multi-Layer Film Capacitors
63V 3900pF 5%
BQ014D0153J-- AVX Multi-Layer Film Capacitors
63V 15000pF 5%
BQ014E0473J-- AVX Multi-Layer Film Capacitors
.047UF 100V 5%
BF014E0104J-- AVX Multi-Layer Film Capacitors
100V 0.1uF 5%
Hope this helps.  I remember reading a post by R.G. about just giving mouser part numbers.  It was the teach a man how to fish saying and I'm only feeding you a fish, but I am hoping that this will inspire you to learn to fish.  Remember, ALWAYS CHECK THE DATASHEET!!!
-Jonathan
