stupid discovery
Started by birt, May 28, 2007, 02:39:29 PM
birt
I made some lofi pedals before but was never satisfied about the sound. it always sounded "fake".
after letting the idea rest for a very long time i got this stupid idea...
I sent my guitar trough a small amp into the speaker of a very old (bakelite old...) phone. then i taped that speaker to the carbon mic of that same phone (search in OT for a topic on how to hook these up) and amplified that trough my guitar amp. instant telephone sound :p
if i built this as a pedal i want to be able to switch to transistor radio sound too, less lows and more biting highs. i haven't figured that one out yet. a second speaker isn't really an option. it would be very hard to tape 2 speakers to one mic and fit that in a pedal...
http://www.last.fm/user/birt/
gez
http://www.diystompboxes.com/smfforum/index.php?topic=56863.0
Similar principle.
A couple of transducers taped together will give you a twangy thin sound.
birt
this isn't really twangy, but the principle is the same
GREEN FUZ
Maybe twangy isn`t the right word to describe it  but it certainly degrades the signal and it gives it a certain resonance. I`m still monkeying around with this idea. I`d love to fit it in an enclosure but it`s difficult to avoid the attendant microphony.
gez
Quote from: birt on May 28, 2007, 03:23:03 PM
I mentioned the transducers (cheap disc type) as it will give a similar sound to a crappy transistor radio (bright/brittle).
birt
yeah, the phone speaker/mic setup doesn't make it bright. it has way more mids and less high. i had the test setup on top of my marshall and even with a lot of volume i didn't get any feedback. i used a ruby type amp with 2 LM386 to drive the speaker part.
brett
Hi
Early transistor radios had fairly poor output transformers (yes, just like tube amps).  I'm fairly sure that using one of those in-line would give a fair bit of cheap radio sound to a signal.
IMO the cheap output transformer is a reason for the fat mids and ringing harmonics (and loss of bass and treble) in the famous "Deacy" amp used by Queen.
cheers
Brett Robinson
