HEAVY DARLING
Started by Dragonfly, January 27, 2008, 03:43:29 PM
Dragonfly
My entry for this months FX-X contest...
The Heavy Darling is a SIMPLE fuzztone that cleans up great, has old school character, and good sustain...pretty much ANYONE who can solder should be able to build this one. It uses a MPSA13 Darlington transistor in the 1st stage that pushes the 2N3904 into full saturation. The 220k resistor limits the amount of saturation, and you could certainly experiment with values here. A pot could also be used to give some variable gain, and you could even set up the pot in a similar manner to the Orpheum, Fuzzrite, and Shin-Ei style fuzzes.
ENJOY !
SOUND SAMPLE #1... Clean amp first, then the same riff with fuzz on !
CLICK HERE FOR SOUND CLIP #2 ...Full on fuzz, some single note soloing, then with the volume of the guitar rolled back !
mnordbye
That's a great contender, indeed! Just dig the sound of your newest creation, Andrew. :)
Magnus N
General tone addict
Deaf Audio at Facebook
bigjim
Too much soldering not enough playing !!
$uperpuma
I LOVE how this sounds with chords.
earthtonesaudio
I like the tone for chords as well.  Nice work.
Dragonfly
Thanks guys. It was something I threw together in about 10 minutes on the breadboard..I love it when that happens ! I'll be developing it further, but I figured I'd post a "basic version" for you guys to build / play with !
Marcos - Munky
Nice, Andy. Another effect on my "to build" list :P.
John Lyons
Sounds great andy!
I was just looking at your site and noticed the schematic there, then saw it here with clips...
The site looks nice, just a start I'm sure.
John
Basic Audio Pedals
www.basicaudio.net/
Barcode80
Andy, permission to post a rough pcb layout i just did?
Dragonfly
Quote from: Barcode80 on January 28, 2008, 12:59:46 AM
Sure ... Post away !
Thanks for asking! :)
GravityRobert
Sounds great, I'd like to make this one  :icon_biggrin:
Dragonfly
Quote from: GravityRobert on January 28, 2008, 07:34:59 AM
Its easy to build sounds great, and none of the resistor values are "critical"...so if you don't have the "exact" value, thats ok...build it anyway !  :)
GravityRobert
Do you have a pic of your pcb? I'd like to etch one in my first batch. This fuzz sounds good  :icon_eek:
PurpleStrat
Everything else aside, you have always made some great Fuzz!
km-r
uh... noob question.
the first tranny is a darlington which should be biased at 1.4 to start conducting. your reading says 3.77V... why is that?
or is the rule "just bias at least 1.4v on the base"????
Look at it this way- everyone rags on air guitar here because everyone can play guitar.  If we were on a lawn mower forum, air guitar would be okay and they would ridicule air mowing.
earthtonesaudio
Quote from: km-r on January 29, 2008, 02:43:31 AM
I don't really know what rule you're referring to, so this may or may not answer your question.
A silicon transistor will cause a voltage drop of 0.7V from collector to emitter, and a Darlington is basically 2 silicon transistors... (0.7 + 0.7 = 1.4V)
Others feel free to correct me if I'm wrong (I'm still a bit of a noob myself).  ;)
But in regards to "rules" in general, stompboxes are a niche of electronics, so many of the rules you read in textbooks don't apply to stompboxes.  We're unconventional.
Barcode80
Bear in mind that though the layout shows one leg of Q2 unconnected, it is actually connected by traces they just somehow didn't end up showing in the graphic.
I guessed at tranny pinout given the usual orientation of PNP silicons because i was just whipping it together, so if it is wrong you may need to do some twisting :)
GravityRobert
Ca anybody verify this pcb?  ;D
Dragonfly
Quote from: GravityRobert on February 11, 2008, 08:34:18 PM
It looks like it has errors...
Q1 is 180 degrees from where it needs to be
Q2 has no connection for the collector
I didnt go through the rest
brett
Hi
Quotethe first tranny is a darlington which should be biased at 1.4 to start conducting. your reading says 3.77V... why is that?
The rule is that a conducting, NPN silicon transistor has a base voltage about 0.7 V DC above the emitter voltage. For Ge the voltage is 0.3 V.
This Darlington consists of two transistors connected emitter-to-base, so the voltage drop is 1.4V (when conducting).  I suspect that the 3.77 V refers to base voltage wrt ground.  If so, the voltage across the emitter resistor is about 2.37 V.
cheers
PS For more fun, you can also work out the emitter current from V=IR.  Once you know Ie, you can calculate the voltage (using V=IR) across the collector resistor because Ic is almost equal (99.8%) of Ie.  That lets you calculate the collector voltage, which is handy to know, because for many circuits it should be about half way between the power supply and ground (0 V) (usually 4 or 5 volts).
Brett Robinson
