PT80 delay: DC voltages of opamp question.
Started by flo, April 21, 2008, 08:45:48 PM
flo
The following voltges were posted for the opamp in the PT80 delay:
http://www.generalguitargadgets.com/diagrams/pt80schem.pdf
http://www.diystompboxes.com/smfforum/index.php?topic=66619.0
TL072
1. 6V
2. 6V
3. 5.9V
4. 0
5. 3V
6. 6V
7. 6V
8. 12V
This what I'm measuring on my PT80 also and the thing works.  :)
But what's bothering me is this:
If pin 5 (+input of opamp B of the TL072) is at 3V, why are pin 6 (-input) and 7 (output) then at 6V?
I expected pin 5 to be at 6V (=Vbias) and pin 6 also. I don't get it...   ???
flo
Bump... Please help me out on this simple question because it drives me nuts:
How can the opamp work ok if its + and - inputs are 3V apart?
The output should have been at 0V then, so why isn't it?
The + input (pin5) should have been at 6V (Vbias) so why is it 3V (measured by me in my PT80 and by others in their PT80s)?
Pushtone
Perhaps the pot locations matter?  LFO? I don't have the schem up in front of me.
Why not email the circuit designer?
Or even the manufacturer. The circuit is just a modified version of the application in the data sheet.
Dave
Is pin 5 the + input that is the input to the effect?
If it is then the reason it is reading 3 volts is because your DMMs impedance is affecting the reading. A lot of DMMs have an impedance of about 1Meg ohm so when you try and measure the voltage at pin 5 the impedance of the DMM forms a voltage divider with the 1M resistor and pulls the voltage down.
Here's a dodgy drawing to make it clearer, because I'm bad at explaining things :)
Point R 6volts ------1M---------Pin 5
                                    1M impedance of DMM
                                 Ground
The voltage on the pin is probably really 6 volts or as you've said the circuit wouldn't work. If you need to measure it accurately you can make a buffer out of a Jfet input opamp connect the probe to the input of that and take the output to your DMM. The buffer will have an impedance of 100s of Megs so it won't load the voltage down.
flo
Quote from: slacker on April 23, 2008, 01:08:20 PM
Yes it is.
That must be it: The impedance of the DMM.
My DMM and my oscilloscope probe both measure 3V so they probably both have a resistance around 1M.
So if I lower the 1M bias resistance that goes from Vbias to pin5 temporarily to 100k, I should measure 6V again...
And indeed! I just put a 100k resitance parallel over the 1M bias resistor and measured the voltage on pin5: 5.56V.
@slacker: Thanks a lot! The world of electronics makes sense again...  :)
