Build Report DR BOOGIE (BOOGEY) with sound clips
Started by rogeryu_ph, June 02, 2008, 04:01:30 AM
rogeryu_ph
DIYer,
Hi, just finished Dr Boogie (Boogey) project.
http://i186.photobucket.com/albums/x139/rogeryu_ph/DrBoogie.jpg
I used four J201 and one MPF102
Here's the details
                      RS     RD        G          S         D
Q1 - J201 -     1.8k   18k      0.00v  0.38v  4.98v
Q2 - J201 -     1.8k   20k      0.00v  0.33v  4.96v
Q3 - J201 -     3.9k   33k      0.00v  0.46v  4.99v
Q4 - J201 -     1.8k   15k      0.00v  0.43v  5.12v
Q5 - MPF102  1.2k    none   5.12v  5.78v   8.87v
Power supply regulated 9.37V
At first, I used all J201 Fet but this high gain circuit was sure hard to tame.
So I experimented MPF102 at Q1 and the result was not meaner or aggressive like all J201 components so I shifted to Q5 the results was very cool, I was able to tame the squeal and retained the agressiveness plus now I could dial up my Boogie volume until 3'0clock before it squeal. This thing is very loud :icon_biggrin: Quarter to half volume and AMP set to mid volume on band practice is enough.
Mod: Tonestack
I only use the treble pot 25 kB as my TONE knob. I change 6.8nf into 1.5nf to scoop the mid, change C11 22nf to 1uf for more bass, replaced 100k fixed resistor for bass pot, 2k resistor for mid pot, 10k resistor for presence pot.
Mod: Drive pot
I substitute 1meg and used 500kA, I hear no difference using 1meg maybe slight I don't know... beside I'm reserving it  to mode my tubescreamer drive pot. Also, I series 50k resistor between ground and lug 1 of the drive pot so when turn minimum drive is not awkward.
Unfortunately I don't have a good quality camera to capture more of the tone just a pocket size camera. Anyway here's some clips hope would inspire..
http://www.youtube.com/watch?v=gQ3R6OXrjbw
Bass side TONE max on left
http://www.youtube.com/watch?v=dj-jjSJ5GQQ
Treble side TONE max on right
http://www.youtube.com/watch?v=8t_rD1v1JcU
Many thanks to Electrictab, Gaussmarkov layout that I used, R.G, Aron, Jack Orman, Dschwartz from Chile, Mark Hammer and all the member here in the forum and more power to you people :D
Cheers,
Roger
tranceracer
WOW!   :o  That thing sownds awsome!  Sweet build, Good playing too!    :icon_cool:
km-r
Look at it this way- everyone rags on air guitar here because everyone can play guitar.  If we were on a lawn mower forum, air guitar would be okay and they would ridicule air mowing.
kawayanstrat
Quote from: rogeryu_ph on June 02, 2008, 04:01:30 AM
DIYer,
Here's the details
                      RS     RD        G          S         D
Mod: Tonestack
Mod: Drive pot
Cheers,
Roger
Bro,salamat sa pag-post!(thanks for the post)  :)
dschwartz
Tubes are overrated!!
http://www.simplifieramp.com
DougH
Tonewise, technique-wise it sounds fantastic. You are a good player too. :icon_wink:
My only friendly criticism is please tune your guitar- esp in the first vid it really sounds off with that first chord. :icon_wink: :icon_wink:
But otherwise it sounds really nice. Good job! :icon_wink:
dschwartz
Quote from: DougH on June 02, 2008, 01:26:42 PM
i have to differ here :icon_rolleyes: ...but when building these beasts, who has time to practice??
rogeryu_ph
Guys,
That's the problem when your guitar doesn't have locking nuts :icon_lol:  Constant tremolo dive will slightly off tune some old string. I forgot to retune after some practice before I recorded the clip. Excited huh...
BTW I only used Wah on Voodoo part on bass clip and the rest only Boogie with Fender amplifier tone set up all to 12'0clock level.
Furthermore, I forgot to say I used one tantalum 1uf only on the q4 source that stop feedback. I'm not sure if this was the remedy.
R.G. /Gaussmarkov/Electrictabs what's the difference using polarized and non-polarized cap on those fet source to ground? Anyone... Gaussmarkov indicates non-polar on his schem but Electrictabs uses polorized.
Also I forgot Km-r my fellow Filipino DIYer also here in the forum that's introduced me to Dr Boogie.. Thanks Kimar.
Dschwartz, that's also my problem before, when I did learn DIYing I almost got no time for guitar practicing.... But I later realized my main goal was PLAYING GOOD GUITAR :'(
So I did change my rule "Practice first before DIYing" Sort of balancing both hobby.
Hi Kawayanstrat, nice to know your a filipino also Mabuhay.....
Kampai,
Roger
dschwartz
yeah.. time is not free...
i used to play really, really good..4 dr boogies later, 2 tube amps, 2 burning crunchs, and a few more effects later.. i SUCK!!!!!!!
my arsenal of licks is like 1% of before..i really truly suck now..
rogeryu_ph
 Wish that I know how to build my own tube amps dschwartz..... :(
Can you link me to some basic building guide.... sort of starter or small wattage tube amp to begin with....
Roger
Hanglow
I love my dr boogie too, it's probably the best distortion pedal I've made and even played. I also second the DIY eating into playing time :D It needs  balance.
rogeryu_ph , I just started with amps as well, here are some of the places to go
http://www.sewatt.com  - for single ended amps, there are sub forums for modding the likes of Valve Juniors, which is what I started on.
http://ax84.com - a number of different amps to try, have alook at the p1 or p1 extreme for a first build
http://www.aikenamps.com  - loads of great info
http://www.diycustomamps.com/princeton.htm  - tweed princeton layout and a few other useful articles etc
You will find there are a lot of members of this place that also post on ax84 and elsewhere, there is a lot of crossover. good luck
dschwartz
definetly, dr boogey is the best (if you like metal and shred. it even can handle a little blues)..i use it with an eq for live situations and man!!! it totally kick ass!!!
about the tube amps.. well, i have to say that is no picninc building one of those.. it take a lot of hard work.. and i´m not speaking a bout the electronics.. finding párts, making the chassis, the holes, the freakin´wiring...geezz.. you have to be like a master woodcrafter, tool maker, metal worker, and even a priest (to pray God to make the thing work)..
I started with a jcm800 for a friend who got all the parts first, and he made the craftsmanship. i just did the electronics part (it was my first project!!!!, but i had a bit of an electronic background, and knew how to read schems and all)..it took us 6 months to make the thing work. but it never distorted!!!!
(we recently opened it up, and realize that i connected the input to the 2nd stage..no wonder it was so clean.. now is ok)
the second amp is a fender PA100 i totally gutted out and remade the circuit ( my design)..the chassis and parts were already there..
i totally reccomend aiken amps page..really good info there..
DougH
Most of the diy-ing I do anymore is amps. They are just a lot of fun. But the woodwork and chassis machining is a lot of work.
John Lyons
Quote from: DougH on June 03, 2008, 10:20:19 AM
That's why I get paid the big bucks.  Yeah right!  sigh....
john
Basic Audio Pedals
www.basicaudio.net/
spud
Hey rogeryu -
Try ax84.com for low wattage tube amps -
spud
spud
Oh and BTW - Good Job, like the sound and the playing is great!
spud
rogeryu_ph
Wow man thanks guys for your input... Hanglow for the links... Dschwartz, John, DougH and spud for the tips.
There are many local electronics shop and store in our downtown mostly making their own model solid state   amplifier with thier own mojo. Some are for karaoke and have for instrument amplifier too. Maybe I could order the woodworking part for them but the only problem is the vacuum tube parts availability.
Thank you so much,
Roger
kawayanstrat
Quote from: dschwartz on June 03, 2008, 12:20:25 AM
+1 on that,man! I've built 7 Dr.Boogeys,2 BSIABS,10 fet boosters,20 ZD clones,1 delay,1 chorus and a compressor, and it did hurt my guitar playing abilities. :icon_cry:
tranceracer
Quote from: kawayanstrat on June 04, 2008, 03:31:36 AM
I hear you guys, making these do take lots of time and energy especially to build some of the FANTASTIC pedals that have been shared by the talented and not-so talented (me) on this forum!  I'm almost the opposite, with figuring out 4 songs, recording tunes in Reason and Cubase, dialing in tones on outboard effect processors and video editing, my poor 2nd half built Matsumin Tube OD is still sitting in it's box waiting for a home...  BUT my 1st generation Matsumin IS a major part of my rig/sound right now tho!   :D
dschwartz
It´s a pretty ironic issue..
i used to play like 2 hours a day, to a point i could play my ass off..started perfectioning my sound, and making my own gear, and suddenly i am more skillful with the soldering iron than with the guitar, reading resistors at the fly, understanding circuitsand stuff..
it´s like that "married with children" chapter, when Kelly has to learn sports facts and starts to forget everything she already knew cause there was no more space in her head..
