so... how do you guys do it?
Started by eleanor296, July 27, 2008, 12:53:27 PM
eleanor296
I've been trying to find some threads about it using the search function, but no luck...  maybe it's my bad English  :icon_question:
Anyway, how do you guys attach your perfboards in your enclosures?  I'm sure there are several ways to do it, as I have thought of a couple different ones myself, but I'd like to hear everyone's preferences.  I find it quite interesting that there is not more "talk" about this subject.
Thanks for your help guys!
This question might at first strike you as rather "dumb", but I hope it's not!
~Andy
GREEN FUZ
If you type "standoffs" or "stand-offs" into search you should find loads of threads. This isn`t meant as one of those "use the search function" rebukes, just a suggestion.
Cardboard Tube Samurai
For most of them, I use standoffs. For smaller, more basic circuits, or for ones I make on vero, I simply hot-glue them in
eleanor296
Quote from: GREEN FUZ on July 27, 2008, 01:24:29 PM
Hey Green Fuz,
no offense taken.  So standoffs is what they are called?  Sorry, I just didn't know what I should be searching for.  I tried "perfboard attachment enclosure", but, as you can imagine, I didn't get anything good  :icon_biggrin:.
Anything else I can use that I can get at, let's say, Lowe's?
eleanor296
I just found another thread where someone said something about velcro.
I think that's THE idea!!!
Hmmm.... won't it loosen up though after a while?  Especially if you stomp quite a bit?
~Andy
The French connection
Hi! What do you think of double faces tape....the foamy style one...it works for me!
Dan
I know, but the pedal i built does not boost...it just increases volume!
My picture files:
http://www.aronnelson.com/gallery/main.php/v/French+connection/
http://s193.photobucket.com/albums/z4/letournd/Pedal/
Barcode80
Quote from: eleanor296 on July 27, 2008, 11:22:12 PM
~Andy
nope. you are never actually stomping the velcro. the insides of a pedal sustain little to no shock unless you stomp hard enough to flip the pedal into the air. if so, do yourself a favor and stop playing, just hang up the guitar....  :)
andrew_k
Quote from: The French connection on July 27, 2008, 11:27:06 PM
If it suits the board and layout, I use double-sided foam tape and attach the the board to the back of the pots.
Radamus
I'm sure this is horrible stomp box-making, but I don't usually bother. I find that things fit better if I allow the solder side of the board face down, with electrical tape covering the bottom of the enclosure. Haven't run into too many problems so far. I don't move them much or stomp all that hard. Things seem to fit into smaller enclosures this way, and the wires point out of the board into the knobs, etc.
Roobin
If you have those enclosures that have the ridges on the insides, then if the board is small enough, you just cut it out to the size of the inside and slot it in. Works well, just watch out the edges - if you have any traces there, it may be wise to use some insulating tape.
jayp5150
Dan
That's what I use.
eleanor296
what do you guys mean with "the foamy kind"?
bside2234
They mean the kind with foam sandwiched between two pieces of tape. Like the 3m double-sided sticky squares.
Quote from: bside2234 on July 28, 2008, 10:04:57 AM
Exactly! You can have it in square pad that you cut, tiny precut rectangle or in roll like this one...
Dan
My picture files:
eleanor296
aaaahhh... gotcha  ;D
where do you guys get it?  Any craft store?  Lowe's, Home Depot, etc?
Yes, I'm lazy.   :icon_mrgreen:  Throw me a bone.
Quote from: eleanor296 on July 28, 2008, 10:12:05 AM
just kidding...personnaly, any 1$ store will do the job...and you can buy some 1$ lecture lamp and scavage the led or use it for lighting you pedalboard...
Dan
My picture files:
lontano
i'm new at this too, and not having found the info on the forum i decided to directly attach the board to the switch, so it doesn't move and it's easy to work with... i'm not sure it's the best solution, but that's what i've done in the 3 messy boxes i've made so far
newfish
Major externals (switch and sockets) mounted on-board, so the board is held in place in 3 pretty strong places.
I'm not that heavy, and treat my gear nicely - it should last quite a while...
Happiness is a warm etchant bath.
eleanor296
also not a bad idea, newfish, but I like to be a little more "modular".
Thanks for all the suggestions!
I'll try the tape probably.
I was originally going to Gorilla-glue screws into the enclosure, put'em through the holes in the perf, then use nuts to secure everything.
~Andy
