RAT/DS-1 Like Boss OS-2 distortion channel
Started by WGTP, December 06, 2008, 02:15:49 PM
WGTP
http://www.aronnelson.com/gallery/main.php/v/WGTP/OS-2+Distortion.GIF.html   I don't remember if I posted this before or not. :icon_rolleyes:
Here is the original from Brian.  http://www.aronnelson.com/gallery/main.php/v/Schematics-and-diagrams/Brian-Wampler-Indyguitarist/temp_boss_os2_truebypass.gif.html
The Boss OS-2 Overdrive/distortion pans between a SD-1/TS type overdrive and a DS-1/Rat type distortion.  This is the distortion channel.
It is Rat like with a notch filter and TS/SD-1 Tone control.   :icon_eek:
Definitely experiment with the values in the notch filter to personalize your own balance of hi/mid/lo.  At least socket the caps (18n & 100n).  :icon_twisted:
IF you want a MEANER Rat with a more modern sound, this is it.  You could even use the vintage correct LM308 Chip if you want to, but it is drawn for a std. dual op amp.  4558/4559/OP275/5532/072/??? should work fine.  I think RS has the TL082 and the rest of the parts although some part values maybe be hard to come by.   :icon_cool:
Stomping Out Sparks & Flames
WGTP
