4PDT Switch Layout Questions. (2 rows 6 lugs VS. 4 Rows 3 lugs)
Started by marsonic, May 11, 2009, 11:15:10 AM
marsonic
Hey Everyone!...This may be Lame and Obvious..but Im confused!.. This is probably wrong..but if anyone could let me know or correct it that would be AWESOME!
http://i20.photobucket.com/albums/b232/marsonic2/4pdtlayout.gif
Someone told me that the second lug from each end was the center row?? ..(hence the switcharound)
Want to make this.
http://www.beavisaudio.com/techpages/PedalHacker/OrderSwitcher.gif
Jason ::)
Ice-9
the best way to confirm it would be to use a meter, connect one lead to the second leg in and test each side of this with the other lead, switching should swap the on connection to either side of the second pin if this is indeed how the switch is working.
If thats correct draw a line in your diagram passing vertically between pins 2 -3  and 10 -11 and rotate both blocks 90 degrees and its the same as in the second wiring diagram
www.stanleyfx.co.uk
marsonic
Thanks !..I figured out how the switch works....
I really just need to complete this chart correctly
http://i20.photobucket.com/albums/b232/marsonic2/4pdtchart2.gif
The Diagram from the place I bought it is
http://www.effectsconnection.com/images/ebay/4pdtdiagram1.jpg
marsonic
Quote from: marsonic on May 11, 2009, 12:43:48 PM
I was sent a Diagram (just now)..of the Actual switch ....Im getting closer...
Now just need to know if its Logical,like this:
or do I Switch the 4-5-6 & 7-8-9?
trixdropd
This should clarify for ya...
and as you numbered them should be this...  top 1 2 3      4 5 6      7 8 9     10  11  12
                                                            Bottom 1 5 9     2 6 10    3 7 11    4  8  12
marsonic
Thanks AGAIN!.For everyones Help!...EXTRA SPECIAL THANKS TO JOHN AT EFFECTSCONNECTION.COM for the Diagram!
GOT IT!!
