9v transformers in Aus for $1 each
Started by composition4, September 17, 2009, 07:57:40 AM
composition4
For those of you who may consider building RG's "Spider" power supply... the one with lots of isolated 9v transformers:
Description:
"Specification: Input: 240VAC Output: 9V @ 150mA Size: 37(W) x 31(H) x 33(D)mm **** Please note 100 Ohms resistor in series with output lead. Can be cut off if not required"
Perfect for the job and really cheap too. I've bought from the website before and they're really good, only thing is $12 postage - no problem if you're buying things in bulk though
http://www.excesselectronics.com.au/index.php?main_page=product_info&products_id=681
Jonathan
trixdropd
Quote from: composition4 on September 17, 2009, 07:57:40 AM
Description:
Jonathan
says 5$ when i view the site.
Toney
 Look again.... (5 units= $5)  ;D
Great call on that site. A combination of superb value and so/so. I'll be ordering there for sure.
100 x 100k trimpots with handy-dandy thumbwheel for $5
Check it out
http://www.excesselectronics.com.au/index.php?main_page=product_info&cPath=74&products_id=671
Tonemonger
Note to self :- 1. Write last will and testament.
                     2. Leave everything to Composition4.
Thanks man.
