Some one…Help us with a tuner project, please
Started by solderman, April 10, 2010, 04:05:13 AM
solderman
Hi All
One thing that bugs me is that I do not have an ALL DIY pedal board. The tuner is still some thing that I have bought. I want to build a tuner and sell off my factory built one. The thing is that this requires an "Easy to understand digital DIY project made for else analog folks" like my self. Since I have no intention to dive in to and learn all about the digital part of this world. I would like to find a project that;
A has the schematics for the components etc.
B Has the source code to program the digital part.
C Has a "Tuner building for dummies" Instruction for how to go about "B" for a newbe in that area.
Some thing that works and does the normal tuning job like my BOSS does. I do not have to have all the gadgets and be chromatic. LED:s are fine. Of cause chromatic and display is a nice thing to have but no need.
I have tried some IC40XX analog stuff projects before on bred board but that was too messy and unprecise.
I have googeled and searched here and there but only found some half OK projects with too little info to guide a dummy like me to the goal.
Is There Anybody Out There?" –(2:44, R.Waters)
The only bad sounding stomp box is an unbuilt stomp box. ;-)
//Take Care and build with passion
www.soldersound.com
xSolderman@soldersound.com (exlude x to mail)
Scruffie
Here's a DIY Tuner project, pretty simple and no digital, haven't tried it http://rock-tiras.km.ru/tuner.rar
There's also this... not sure about this one... but neither involve anything digital.
http://experimentalistsanonymous.com/diy/Schematics/OOP%20Japanese%20Electronics%20Book/tuning-indicator.gif
arma61
"it's a matter of objectives. If you don't know where you want to go, any direction is about as good as any other." R.G. Keen
mth5044
Quote from: Scruffie on April 10, 2010, 04:19:12 AM
Hmm a strobe tuner from 1980? This looks interesting. Hopefully someone has tried it before or at least can tell if it is going to work without supporting circuitry, as it looks pretty easy.
solderman
Thanks'
I thinks the first one wast the one I found and bread boarded with no success so I think i'll still wanne go digital. Has to be a reason why all comersials are digital.
www.soldersound.com
solderman
#5
Quote from: arma61 on April 10, 2010, 05:56:40 AM
Hi
have you seen this
http://www.diystompboxes.com/smfforum/index.php?topic=80673.0
It doesn't look complex providing you have the chip!
Ciao
Armando
YES
Thanks' a mill Armando. This made my day , week, or maybe month. It's EXACTLY the sort of project I've been looking for.
-Easy
-well described with source code etc
-Chromatic and LCD display + and Hi-OK-Lo LED
-And the BIG bonus, it will fit in a 1590A so it will match the rest of the gear.
Still, I have to practise on my search skills. It was there so I should have found it.    :-[
www.soldersound.com
arma61
Glad I could help m8
the only "issue" would be to cut the square hole for the display
pls report back if/when you build it
Ciao
solderman
Quote from: arma61 on April 11, 2010, 05:24:01 AM
Ciao
Of cause
No problem
One hole in each corner and cut between.
I plan to use this one. Its so small i Can fit a stomp switch too.
https://www1.elfa.se/data1/wwwroot/assets/datasheets/DEM16223SYHPY_Datasheet_EN.PDF
www.soldersound.com
differo
Is there a source code there? I couldn't find it, only hex. It would be nice to experiment with it prior to programming the pic.
My youtube channel:
http://www.youtube.com/user/BeToneful
Rebote2.5,MXR dist+,DrBoogie,BSIAB2,Ross Compressor&Phaser,MXR EnvFilt &Noise Gate,TS808,Condor CabSim,SansampGT2,Fraverb,Small Clone,TremLune,ValveCaster
solderman
#9
Quote from: differo on April 12, 2010, 05:48:45 AM
Did not find any You might get it if you contact "Mr schickt" here
http://schickt.de/contact.php
Or you can go here
http://mattzz.dyndns.org/wiki/bin/view/Projects/GuitarTuner
Here you can find a source code in Asambler for a project I thing he based his on. It has not got the Lo-OK-Hi LED but you might be able to get the basic out of there.
www.soldersound.com
