Bulk Parts
Started by 59strat, September 18, 2010, 11:52:42 AM
59strat
Looking to stock up on stuff so i can build a few pedals without having to buy individual parts each time I want to build a pedal.
I am looking for
Resistors, Caps, IMs, Diodes, Transistors etc
Is this still about the best value going:
http://www.futurlec.com/ValuePacks.shtml
Does anyone have a good list of like order a lot of different varieties instead of getting random selection such as
XX,XY,XZ resistors
XX,XY,XZ caps
Any new things out there?
Thank you in advance.
Hupla
Completed builds: BSIAB2
Pedals to build: Dr.Boogey, TS-808
CynicalMan
jkokura
Topmay and Panasonic film caps from Smallbear in bags of 100, Metal Film Resistors on Ebay, Ceramic Caps and other parts like transistors and diodes from Mouser, Pots and knobs and IC's from Smallbear, Enclosures 3PDT's and DPDT's from PPP, and I can't think of what else.
Jacob
LucifersTrip
Quote from: 59strat on September 18, 2010, 11:52:42 AM
I am looking for
No, the best deal is Tayda. You can pick the exact parts you want and it's the same or less expensive that those value packs.
Tayda is also much faster and the shipping will also be less (unless you order heavy items like pots).
Resistors (same $ as Futurlec val pack, but you pick exactly what you want)
http://www.taydaelectronics.com/servlet/the-Resistors-cln-1-fdsh-4W-Carbon-Film-Resistors/Categories
Caps (you get and extra 100 Caps for the same price as Futurlec val pack + pick exactly what you want)
http://www.taydaelectronics.com/servlet/the-Capacitors-cln-Ceramic-Disc-Capacitors/Categories
Tran (2-3 cents each for common values instead of the 5 cent Futurlec value packs + pick exactly what you want)
http://www.taydaelectronics.com/servlet/the-Transistors-cln-2N-Series/Categories
same thing with common diodes
http://www.taydaelectronics.com/servlet/the-103/1N4148-Diodes-DO-dsh-35-Switching/Detail
have blast
always think outside the box
59strat
Quote from: LucifersTrip on September 18, 2010, 04:44:23 PM
I am looking for
have blast
Just getting back to this...
YOUR LINKS ARE FANTASTIC!
I used the page with the most common values, printed it and then went to the site you linked.
THANKS!
anchovie
Quote from: jkokura on September 18, 2010, 01:18:09 PM
Or carbon film resistors in blue packages, depending on which country they're coming from!  ;D
jefe
I am looking for
have blast
Nice find! I just checked them out, the prices look better than Futurlec's. PT2399 ICs for $0.54!  :icon_eek:
p_wats
+1 for Tayda.
I was wary at first but then placed two orders with them last month for a crap load of stuff and it all arrived quickly and very well packaged. Great customer service as well (and a constantly growing collection).
59strat
Just a order recap for those interested.
Here is my order I just placed:
Tayda Electronics Items
    25 Resistor 1.0M Ohm 1/4W 5% Carbon Film  @ $0.01 = $0.25
    25 Resistor 10K Ohm 1/4W 5% Carbon Film  @ $0.01 = $0.25
    25 Resistor 100K Ohm 1/4W 5% Carbon Film  @ $0.01 = $0.25
    25 Resistor 470K Ohm 1/4W 5% Carbon Film  @ $0.01 = $0.25
    25 Resistor 1K Ohm 1/4W 5% Carbon Film  @ $0.01 = $0.25
    25 Resistor 22K Ohm 1/4W 5% Carbon Film  @ $0.01 = $0.25
    25 Resistor 47K Ohm 1/4W 5% Carbon Film  @ $0.01 = $0.25
    25 Resistor 100 Ohm 1/4W 5% Carbon Film  @ $0.01 = $0.25
    25 Resistor 2.2M Ohm 1/4W 5% Carbon Film  @ $0.01 = $0.25
    25 Resistor 4.7K 4K7 Ohm 1/4W 5% Carbon Film  @ $0.01 = $0.25
    25 Resistor 33K Ohm 1/4W 5% Carbon Film  @ $0.01 = $0.25
    25 Resistor 220K Ohm 1/4W 5% Carbon Film  @ $0.01 = $0.25
    25 Resistor 2.7K Ohm 1/4W 5% Carbon Film  @ $0.01 = $0.25
    15 Resistor 8.2K 8K2 Ohm 1/4W 5% Carbon Film  @ $0.01 = $0.15
    15 Resistor 150K Ohm 1/4W 5% Carbon Film  @ $0.01 = $0.15
    15 Resistor 470 Ohm 1/4W 5% Carbon Film  @ $0.01 = $0.15
    15 Resistor 560K Ohm 1/4W 5% Carbon Film  @ $0.01 = $0.15
    10 Resistor 2.2K Ohm 1/4W 5% Carbon Film  @ $0.01 = $0.10
    20 0.1uF 100V 5% Mylar Film Capacitors  @ $0.05 = $1.00
    15 0.1uF 50V Ceramic Capacitor  @ $0.01 = $0.15
    10 0.01uF 100V 5% Mylar Film Capacitors  @ $0.04 = $0.40
    10 10uF 25V 105C Radial Electrolytic Capacitor 5x11mm  @ $0.03 = $0.30
    10 1uF 50V 105C Radial Electrolytic Capacitor 5x11mm  @ $0.03 = $0.30
    15 4.7uF 35V 105C Radial Electrolytic Capacitor 5x11mm  @ $0.03 = $0.45
    10 100uF 25V 105C Radial Electrolytic Capacitor 6x11mm  @ $0.03 = $0.30
    10 47uF 50V 105C Radial Electrolytic Capacitor 6x11mm  @ $0.03 = $0.30
    10 3.3uF 50V 105C Radial Electrolytic Capacitor 5x11mm  @ $0.03 = $0.30
    10 0.01uF 50V Ceramic Capacitor  @ $0.01 = $0.10
    10 0.047uF 50V Ceramic Capacitor  @ $0.01 = $0.10
    10 0.047uF 100V 5% Mylar Film Capacitors  @ $0.04 = $0.40
    10 0.022uF 50V Ceramic Capacitor  @ $0.01 = $0.10
    10 0.022uF 100V 5% Mylar Film Capacitors  @ $0.04 = $0.40
    10 0.001uF 50V Ceramic Capacitor  @ $0.01 = $0.10
    15 0.0022uF 50V Ceramic Capacitor  @ $0.01 = $0.15
    5 0.22uF 100V 5% Mylar Film Capacitors  @ $0.05 = $0.25
    10 1000pF 0.001uF 100V 5% Mylar Film Capacitors  @ $0.03 = $0.30
    5 22uF 50V 105C Radial Electrolytic Capacitor 5x11mm  @ $0.03 = $0.15
    10 0.22uF 50V Ceramic Capacitor  @ $0.01 = $0.10
    10 220uF 25V 105C Radial Electrolytic Capacitor 8x11mm  @ $0.06 = $0.60
    15 560pF 50V Ceramic Capacitor  @ $0.01 = $0.15
    10 4700pF 0.0047uF 100V 5% Mylar Film Capacitors  @ $0.03 = $0.30
    15 22pF 50V Ceramic Capacitor  @ $0.01 = $0.15
    1 10 x BC547 BC547B Transistor NPN 45V 0.1A  @ $0.19 = $0.19
    1 10 x BC548 Transistor NPN 30V 0.1A  @ $0.29 = $0.29
    1 10 x 2N3906 PNP General Propose Transistor  @ $0.29 = $0.29
    1 10 x 2N3904 NPN General Propose Transistor Kit  @ $0.19 = $0.19
    10 1N4148 Diode DO-35 Switching Signal  @ $0.01 = $0.10
    5 LED Blue Ultra Bright Water Clear 3mm  @ $0.04 = $0.20
    1 10 x 1N4001 1A 50V Diodes  @ $0.10 = $0.10
    1 CA3130EZ CA3130 IC OPERATING AMPLIFIER  @ $1.26 = $1.26
Sub-Total: $13.42
Shipping: $8.50 (All Countries Standard 7 to 16 days)
Sales Tax: $0.00
Tayda Electronics Total: $21.92
Store Credit: -$0.00
TOTAL DUE: $21.92
I just thought others may be interested to see what I got for what prices
edvard
Earthscum
+1 I'm loving Tayda for small parts... pots get expensive for just a couple (shipping goes up), but... here's another example list I just ordered last week.
       2- 10 x 2SA1015 2SA1015Y TRANSISTOR PNP 50V 150MA @ $0.19 = $0.38
       2- 10 x 2SC1815 2SC1815Y C1815 TRANSISTOR NPN 50V 0.15A @ $0.19 = $0.38
       6- CD4013 4013 IC CMOS DUAL D FLIP FLOP @ $0.18 = $1.08
       6- CD4017 CD4017BE 4017 DECADE COUNTER/DIVIDER IC @ $0.36 = $2.16
       6- CD4066 4066 IC CMOS QUAD BILATERAL SWITCH @ $0.22 = $1.32
       2- OP07 Operational Amplifier Precision PDIP-8 OP07CP @ $0.34 = $0.68
       10- CR02 SCR 0.3A 400V 100uA TO-92 CR02AM-8 @ $0.20 = $2.00
       1- ULN2004AN ULN2004 TRANSISTOR ARRAY-7 NPN @ $0.25 = $0.25
       10- 0.1uF 100V 5% Mylar Film Capacitors @ $0.05 = $0.50
       10- 0.01uF 100V 5% Mylar Film Capacitors @ $0.04 = $0.40
       10- 1000pF 0.001uF 100V 5% Mylar Film Capacitors @ $0.03 = $0.30
       6- 4700pF 0.0047uF 100V 5% Mylar Film Capacitors @ $0.03 = $0.18
       6- 2200pF 0.0022uF 100V 5% Mylar Film Capacitors @ $0.03 = $0.18
       6- 0.47uF 100V 5% Mylar Film Capacitors @ $0.05 = $0.30
       6- 0.022uF 100V 5% Mylar Film Capacitors @ $0.04 = $0.24
       6- 0.047uF 100V 5% Mylar Film Capacitors @ $0.04 = $0.24
       6- 0.22uF 100V 5% Mylar Film Capacitors @ $0.05 = $0.30
Sub-Total: $10.89
Shipping: $3.42 (All Countries Standard 7 to 16 days)
Invoice Total: $14.31
jcgss77
So would you recommend Small Bear for Pots then, or someone else?
jkokura
I like smallbear because you can buy multiple values and have them count towards their bulk discount. I don't remember if it's at 10 or at 25, but at some point they become 1$ each. That's cheaper than elsewhere I've seen at least.
Jacob
59strat
Quote from: jkokura on October 05, 2010, 08:48:29 PM
Jacob
Haven't actually tried it yet, so I am not trying to put them down, but I have heard that they are somewhat slow and have made errors on orders more than once.
has this been the standard result for most people?
Again NOT trying to start flame etc just curious...
alparent
Just placed an order also......but took the pots I needed out.
By removing the 10 pots I needed the shipping went down by about 6$ :icon_exclaim:
I will get them from Futurlec ...... I need some stuff from them anyways! There is a lot of stuff Tayda dosn't carrry.
But the prices are amazing......if you watch out for shipping.
LucifersTrip
Quote from: 59strat on October 04, 2010, 07:51:15 PM
I am looking for
have blast
THANKS!
Glad I could help...you should have a blast. Funny thing is when the prices are that low and you want to put in a quick order for caps, resistors & trans, it's hard to get to the $5 minimum!
LucifersTrip
Quote from: alparent on October 05, 2010, 10:59:59 PM
Right, as I wrote in my first post, heavy stuff like pots will jack up the shipping at Tayda. Pots are better from Futurlec since they charge shipping by amount of order, not weight. So when you order from Futurlec, you can get $29 worth of pots with only $4 shipping.
[Note: If you order only 12 pots the price is almost the same at both. Anything over 12 Futurlec wins.]
Unforunately, Futurlec takes 3 times as long for me [I'm in the US]. I get my order in about 2 weeks from Tayda. I put in a [mainly] pot order with Futurlec on Aug 29 and am still waiting. I expect that order very soon.
