Tasteless Broadcaster - Slightly Tweaked Lofo Mofo
Started by Earthscum, February 06, 2011, 04:09:51 AM
Earthscum
This is one that's been sitting in a bag for about 8 months, and I finally got around to getting it done. I have a layout I'll fix and upload in the morning.
I used 2n5088's to calm down the hiss to a tolerable level, then added it back it, I think, with all ceramic caps. It definitely has a sharper sound with caps... more of a plastic sound than with poly's.
The V+ can be 9V or even lower. I didn't measure voltages, but got a hint to check it out when I powered down the effect from my PS. It did the typical clean-up as the supply drained out, but held there way longer than any other circuit. At (somewhere around) 3V, this thing cleans up nicely. I'm going to run it off of a pair of AA's, and use momentary switching, myself. At 9V, it sounds like you have a pocket radio cranked so grandma gets annoyed across the room. Lower voltages are more akin to having it at a tolerable level sitting on your desk, but still loud enough to play some 560AM ZROCK (Gawd I miss that station!)
This is basically what I tuned a Lofo Mofo to be. I added in a bit more filtering and now this sounds more to me like the old black pocket radios I'd have as a kid. (Like These)
Ahh... the old FlavoRadio... when you lick it, it tastes...
like...
Nothing. (seriously, I suck at naming stuff, lol... that's why our band is "Three White Guys and a Black Skater"... they were just too lazy to come up with something better!)
Earthscum
So, I labeled the diode wrong (number). This new schem is good to go. I have a PCB burned, populated, and tested out... no way to get soundclips right now.
This is designed to mount a pot over the top of the components. If your caps are small enough, the transistor is your only limit to height.
Enjoy!
