envelope/edge detection
Started by artifus, February 27, 2011, 02:14:14 PM
Gurner
#60
Quote from: deadastronaut on October 19, 2012, 05:51:46 AM
yep, the led does just cut on/off though....upon further testing.. ::)
With the arrangement you've used, it'll be a struggle to get a slow release thing going on (that's because as I say, the LED is being driven by an amplified AC signal ....vs. a slow changing DC level based on the incoming AC signal). removing the cap C3 won't help you get a slower release.....but it's not helping your end goal at all so IMHO can be removed. Another downside of that circuit you've used is that input impedance is too low for a raw guitar signal (i.e. about 50k).....you want at least 1M of input impedance, which is why it's better to use a non-inverting opamp arrangement.
yeah i took it out...
http://home-wrecker.com/nurse-quacky.html
so this scheme ^  won't give me that ''release''either  then?... :-\
Gurner
#62
Quote from: deadastronaut on October 19, 2012, 06:08:27 AM
IMHO no, (I see they've addressed the aforementioned low input impedance problem by prefacing the envelope circuit with a buffer - though their buffer still only has a 470k input impedance which I think is still a tad low)
@#$%ing envelopes..arghhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh.........................
;D
aha...ive got the fade better by putting a 100uf in parallel with 2 leds....its less snappy....
led.........
            >>>>>led........
cap........
now to suss out how to adjust the bugger.... :P
https://dl.dropbox.com/u/7464107/test1.mp3
as you can hear though, it responds to lower notes, but not the high notes....needs more ass kicking...
this is what i have now...note the switch for fade/staccato. ;D
https://dl.dropbox.com/u/7464107/synthyguitar1.mp3
as you can hear its not sensitive when it comes to hammering/tapping though......hmmmmmmm....
