Loop pedal project
Started by DonB, May 19, 2011, 02:30:01 PM
DonB
I have a project in mind.
Here is a pic
So i want to have main channel select button with a standard on/off loop for my od/boost for when on amps gain channel. Then have a loop from my amps fx loop with simple on/off function for each fx line.
Anyone have any idea how to wire up the channel select and main loop section? My amps vhannel select is via pulse method.
I can make the fx loop as that one is simple. Just have had no luck with channel select/od loop.
