0 ohm resistor as jumper
Started by Seven64, July 10, 2011, 03:27:34 AM
Seven64
so i just built matsumin's tubescreamer vero:
http://www.aronnelson.com/gallery/main.php/v/ulysses/ulysses_layouts/ulysses_ts_srv_special/ulysses_ts_srv_special_vero_1_01.gif.html?g2_imageViewsIndex=1
and got it all together.  it was not passing sound at all, and when engaged the LEd would only turn on when the volume knob on my guitar was between 1 and 3.  other than that it would fade off.  i have the 3pdt switch wired as said in the faq without the grounded bypass.  i used a 0ohm resistor as the jumper for when the switch is in bypass, and got out my multimeter.  i had continuity at the resistor, but not at the place where the jacks were.  i have the part that is supposed to be wired to the pos battery terminal (pole 4) on the 3pdt switch ran to a empty hole right next to the +9 on the vero.  i cut that wire, and get a very faint bypass signal, but nothing from the circuit.
i have continuity from sleeve to sleeve, but thats about it.
Joe Hart
Strange. Can you post pictures?
-Joe Hart
newfish
You probably *have* checked this a couple of times already, but are you *sure* your 3PDT switch is the correct way round?
Doesn't explain the LED lighting issue, but it's one less thing to eliminate.
Happiness is a warm etchant bath.
LucifersTrip
Quote from: Seven64 on July 10, 2011, 03:27:34 AM
i have to admit, this is a bit difficult to follow....but the first thing to do here would be to bypass the switch completely and see if it works first.
always think outside the box
Seven64
i marked one black with a sharpie so when i twisted them coming off the pcb together i knew which one was 'out'
