Push-Pull Pot Wiring
Started by davenoid, December 21, 2011, 12:31:28 PM
davenoid
I would like to build an EA Tremolo with a push-pull pot that disengages the depth of the tremolo when pulled so that the pedal acts as a volume boost. This is a pretty common mod for this pedal, but it's usually done with a toggle switch. I'm using the following wiring diagram from General Guitar Gadgets (scroll to the last diagram in this PDF):
http://www.generalguitargadgets.com/pdf/ggg_eat_mods.pdf
I would like to do the same thing, except with a push-pull pot. Here is the type of pot I am using:
How do I wire the switch part of the pot to toggle into boost mode when pulled? Your help is much appreciated!
CynicalMan
Use pins A and B. Just wire them in place of the two switch pins in the diagram.
davenoid
Quote from: CynicalMan on December 21, 2011, 05:11:17 PM
That worked perfectly. Thank you! You saved me some trial and error.
