Stomp switch went out on my GT2. The actual button on the PCB still works, but the metal stomp part isn't hitting it correctly.
Anyway, does anyone know where you need to de-solder in order to take the board out?
Also I have a 3pdt switch, and would like to swap out for the button if anyone can help with that.
My solder skills are decent, and my knowledge of schematics are little.
Not sure converting the GT2 to 3pdt is an easy task. Maybe the easiset solution would be to get the button to touch the switch again. Check if you can maybe replace or stretch the button spring.
