DIY Stompboxes => Building your own stompbox => Topic started by: jogina111 on January 19, 2013, 12:01:08 PM
Title: ROG's little gem pots
Post by: jogina111 on January 19, 2013, 12:01:08 PM
I built the little gem from ROG but I forgot about the pots. All I have are 10k pots for this project but it requires  5k pot and a 25ohm pot..can I use the 10k pots or is there a way to make 10k pots to work like 5k and 25ohms pots?
Edit: I've read about reducing a pot's value by connecting a resistor in parallel with the pot but I dont know what values to put in.
Title: Re: ROG's little gem pots
Post by: armdnrdy on January 19, 2013, 06:41:25 PM
This might help!
http://www.electronics2000.co.uk/calc/series-parallel-resistor-calculator.php
Post by: jogina111 on January 20, 2013, 12:05:52 AM
I forgot, how should the resistor connect to the pot? Where should I connect the resistor leads? And how would it affect the  circuit if I use a 10k pot instead of a 25ohm rheostat?
