DIY Stompboxes => Building your own stompbox => Topic started by: ElectricDruid on January 15, 2014, 01:14:42 PM
Title: Combined LFO/BBD Clock chip for Chorus/Flanger
Post by: ElectricDruid on January 15, 2014, 01:14:42 PM
Hi All,
I've been working on a new chip. It's a replacement for the MN3102 BBD clock chip done with a PIC. The benefit of this is that I can include the LFO on the chip as well, and can add a load of extra features that you don't usually get. So far I've got:
1) 25KHz to 500KHz clock output
2) LFO with eight waveforms - triangle, sine, hypertriangle, random (S&H), sine+octave, up/down stair steps, manual (see below) - I'm missing one
3) Manual mode - uses the Rate knob to set the delay time (good for static flanger effects)
4) CV control of LFO Rate, LFO depth, and LFO waveform
5) Top-down or Bottom-up selection for how the depth affects the clock rate
I've got a few more things I'd like to include, like:
6) Tap tempo
7) Clock Range selection to make it easier to set up for Chorus vs Flanger
But I'm posting this because I'd like to hear your ideas too. I need one more waveform, for starters. What should it be? What other options would you like to see?
I've got the prototype working on my breadboard with an MN3209 256-stage BBD, which makes for an excellent flanger, with a range from 0.25msecs out to 5msecs (20:1 range). The whole thing is three chips: the LFO/Clock, the BBD, and a quad op-amp (two mixers, two 12dB filters). I tried to make it simpler, but I can't!
I've also tried it with a MN3207 1024-stage BBD, and that works fine too - that'd be the chip I'd use for chorus. Presumably there's some limit to how many stages it'll drive (due to the BBD's clock input capacitance) but I haven't found it yet. I should give it a go with MN3205 4096-stage and see what happens.
Incidentally, at some point after I started work on this, I was reading some posts on here trying to find details of the Electric Mistress' filtering, and discovered that other people have had the same idea - do an LFO+Clock on a uC. So respect due to Eduard SolderingIronHands and others who discussed the idea long before it had occurred to me!
http://www.diystompboxes.com/smfforum/index.php?topic=91981.msg798163#msg798163 (http://www.diystompboxes.com/smfforum/index.php?topic=91981.msg798163#msg798163)
Thanks,
Tom
Title: Re: Combined LFO/BBD Clock chip for Chorus/Flanger
Post by: midwayfair on January 15, 2014, 01:25:58 PM
This sounds awesome! And if it works with an 05 chip, that will be even more awesome.
For the missing waveform: I really like the "dips" from the TAPFLO. It's subtle in a way that turning down the depth didn't accomplish. It might not be the most exciting thing to add by any means, though.
Post by: Govmnt_Lacky on January 15, 2014, 01:27:04 PM
Sounds like a GREAT idea! Definitely gonna follow this.
Will this LFO/Clock chip be available in DIP format or are we talking SMT only?
Also, you might want to expand the range of the clock. Probably downward to ~25KHz and upward to at least 1MHz. This would cover the spectrum for a lot of chorus/flanger territory.
For reference, the MXR Flanger gets up to ~950KHz. The EHX flangers can go down around 30-40KHz.
Good Luck  ;)
Post by: Mark Hammer on January 15, 2014, 01:27:20 PM
I think a lot of folks would love to be able to hit a momentary switch and have a sweep start at the top or at the bottom, and proceed in ramp-like fashion, as sort of a one-shot.  Now, whether that is best accomplished with a linear ramp or sawtooth, or some sort of exponential one, is another matter.   :icon_wink:
I'm not so sure about the up/down stair step.  Most of what people might want a stepped change for is to be found in the S&H/random mode.  Stepped is also the sort of thing that really only works well if the speed and steps occur fast enough.  I imagine it would be rather tricky to program, but a random S&H mode that had glissando, rather than a hard step, would be appealing.  Alternatively, since one would have little control over the virtual noise-source that dictates the random steps, maybe you want a "more" and "less" random version of random.
But this is a brilliant and highly commendable effort on your part.  I have a couple of MN3209's sitting at home, waiting for their call.  Maybe this can finally send them into active duty.
Post by: Govmnt_Lacky on January 15, 2014, 01:30:33 PM
Quote from: Mark Hammer on January 15, 2014, 01:27:20 PM
Right there with you Mark!
I have a case full of Reticon R510X series BBDs that are dying to be used. This might be the ticket  ;)
Post by: midwayfair on January 15, 2014, 01:36:27 PM
I think a tap tempo single-tap reset like in the TAPLFO would do this --- it would start at the "top of the measure" so to speak (I believe the TAPLFO resets to the "fully on" half of the cycle). If it's hard resetting from any particular place in the LFO sweep, it'll make a little noise in the delay signal and then go back to sweeping at whatever rate it's set at.
One problem I can see with this is that resetting with the tap tempo means that you can't do that sort of effect more than once every few seconds, or you'd set a new rate.
Post by: ElectricDruid on January 15, 2014, 01:43:48 PM
Quote from: Govmnt_Lacky on January 15, 2014, 01:27:04 PM
No, the chip is available as a DIP. I've been using the 16F1503, which is a 14-pin DIP, but you can buy it in SOIC or TSSOP too if you *wanted* it tiny. I'll put code up on my website like I did before, and I'll probably sell programmed chips to people who don't want to mess around with programming PICs (that's the bit where I become unbelievably rich and move to a yacht in the Carribean ;).
Sorry, that can't be done. 500KHz is as fast as the PIC can go. MN3209 is only specified for clocks to 100KHz, and MN3207 is only supposed to go up to 200KHz anyway, so I'm guessing that the MXR uses an unobtainium SAD-something. In practice, the MN32xx's will go up to 450KHz perfectly, but above that, the output signal level starts to drop off alarmingly, so 500KHz is about as far as the BBDs will go.
Quote from: midwayfair on January 15, 2014, 01:36:27 PM
I might be able to put it on a different pin. I've still got one or two free. You're right about a single tap resetting to the 'top' of the waveform though. The TapLFO waveforms were arranged so that the 'start' point wasn't necessarily 0 degrees (e.g. sine wave starts at 90 degrees, etc) and I could do similar here.
T.
Post by: Govmnt_Lacky on January 15, 2014, 01:47:39 PM
I see where you went there Druid! Good show!  ;D  ;) It is the SAD1024 that could go up to 1.2MHz.
What about TZF considerations. Could this be a possible solution? (Sorry but I am not well versed in TZF... just thought I would throw it out there  ;D)
Post by: Mark Hammer on January 15, 2014, 01:54:16 PM
Quote from: ElectricDruid on January 15, 2014, 01:43:48 PM
The datasheet specs for the MN3xxx chips are predicated on them being clocked in unaided fashion by an MN3101/3102.  The current drive of those Panasonic chips is insufficient to overcome the input capacitance of the clock pins on the BBD, and results in a less than square clock pulse when you start to go too high.
If suitably buffered, however, a mundane MN3007 or MN3207 can be comfortably clocked up in the 1Mhz range.  I've witnessed it in person.  The thing with the Reticon "unobtainiums" is that their clock pin input capacitance is low enough that they can manage those ultra-high clock frequencies without needing much help.  Provide the help, and the MN3xxx chips can do the same tricks.
As you note, however, the clock-rate limitation is not found in the BBD here, but in the PIC itself.  Still, if another 40-cent CMOS chip allows for the full clock-range potential of the PIC to be exploitable, why not?
Post by: ElectricDruid on January 15, 2014, 02:12:55 PM
Quote from: Mark Hammer on January 15, 2014, 01:54:16 PM
Did you need to compensate for a level drop at those speeds, Mark, or was the level drop I saw because of the clock pulses starting to round off? (In which case, I assume it wouldn't appear with better buffering)
It's not that simple, unfortunately. It's not a question of buffering the PIC's output, but rather of the maximum rate that the NCO peripheral can be clocked on the PIC. I've been using the internal 16MHz clock, which gives a 500KHz max NCO output (at least after it's been separated into the two-phase clock that's needed for a BBD). If you were using an external clock, you could push it up to 20MHz, which would give you 625KHz, but it's not a big improvement, and it eats another pin.
Post by: Govmnt_Lacky on January 15, 2014, 02:57:37 PM
Quote from: ElectricDruid on January 15, 2014, 02:12:55 PM
Probably just me but...
I would be interested in a version that has a single clock output. The Reticon R510X chips take a single clock input and internally generate the second clock.  :icon_lol:
But... like I said... thats just me and there wouldn't be a general need for that function as most BBDs out there need 2 clock inputs  :icon_cry:
Post by: Mark Hammer on January 15, 2014, 03:07:39 PM
First, what I meant was that the perimeter of what you described the PIC as being able to do was beyond the perimeter of what the appnotes say the BBD is able to do.  Adding buffering would allow the "untinkered" PIC to do all of what it is able to do.  It may not be 1mhz clocking, but getting an MN3209 down to under a half or third millisecond is dramatic enough.
Second, what I witnessed was Mike Irwin's MN3007 adaptation of the A/DA flanger.  There was no discernible change in level as it swept to ever shorter delays.  Keep in mind that it is at the shortest delays that any flanger's worth is displayed.  If the BBD loses any substantial level at highest clock frequencies, then the intensity of the effect should suffer, as the dry/wet balance strays from a perfect 50/50 blend.  I didn't hear any of that.
Post by: ElectricDruid on January 15, 2014, 03:30:43 PM
Quote from: Mark Hammer on January 15, 2014, 03:07:39 PM
I'd be interested to know how the MN3007 and MN3207 differ when pushed. I doubt they're identical. I've been using MN3207/9, because they'll run on the same +5V supply as the PIC, which means the PIC can drive the BBD directly. I've been running the PIC outputs straight into the BBD, with no buffering, and it's ok like that to 500KHz - e.g. even "untinkered" you can go to 500KHz. If you look at it on the oscilloscope, you can see that the BBD signal does start to drop off above 450KHz, but in dB terms it isn't that serious - a handful of dB, not as much as 6dB/x0.5. I can't hear it in the output.
To push it up further, you'd probably need buffering, but since the PIC won't go higher anyway, and since part of my aim was to make a full-featured flanger as simple as possible, I wanted to leave the buffers out. Also, I didn't think 0.25msecs was bad - that's 4KHz, which is pretty high for geetar. I was testing it with a two-ramp-oscillator sequencer loop from my Pro-One and it loves a rich signal like that.
Thanks,
Tom
Post by: Govmnt_Lacky on January 15, 2014, 03:40:59 PM
Could you use one of the unused PIC outputs to drive an alternating clock to a seperate BBD to achieve TZF?
Am I asking stupid questions about this?  :icon_redface:
Post by: Mark Hammer on January 15, 2014, 04:11:08 PM
Quote from: ElectricDruid on January 15, 2014, 03:30:43 PM
Thanks,
Tom
Well, in which case, I think you've pretty much hit asymptote.  A min delay of 250us is well beyond what the vast majority of MN3101/MN3007 or MN3102/MN3207-based flangers will do.  And it would seem that the current drive of the PIC exceeds what the MN310x chips deliver, so problem solved.  Now that I get that part, yeah, no need to tinker or assist the clock.  Job's done.  :icon_biggrin:
The Tone Core Liqui-Flange has some of the modulation waveforms you're implementing.  Its "step" mode is essentially S&H, and the "random" mode is a smoother S&H that  transitions smoothly from one random high or low point int he sweep cycle to another one.  The Saw up and Down are interesting as is the envelope and triggered waveform modes.  Unfortunately, the envelope and trigger modes require that a DSP or PIC keep tabs on the state of the input signal, where I gather your implementation treats the LFO and audio path as largely independent entities....which makes perfect sense given the limitations of the PIC itself.
Post by: armdnrdy on January 15, 2014, 04:17:33 PM
What if you use the PICs internal clock and separate it into the two-phase clock externally.
The Mutron Flanger uses this arrangement with a 4046 for the clock and a 4011 to split and buffer.
(https://dl.dropboxusercontent.com/u/53299166/DIYstompboxes/Mutron%20Flanger%203007%20Vbias.jpg)
Great work by the way!
Post by: ElectricDruid on January 15, 2014, 04:58:01 PM
Quote from: armdnrdy on January 15, 2014, 04:17:33 PM
This is possible, but it wouldn't gain you anything. The internal NCO has a "Fixed Duty Cycle" mode, which toggles the output at the NCO rate - e.g. it makes a square wave. This is exactly what you'd do externally, since if you wanted it faster, you'd be getting a narrow pulse, and have to feed it to a flip-flop to square it up. I've got this set up so it feeds the CWG "Complementary waveform generator" which generates a two-phase clock and adds the appropriate dead bands. The small amount of time when *both* clocks are off helps. It seems to give the switches in the BBD time to really go off, and lets you push the clock higher.
All in all, the internal peripherals are *too* perfect for this job *not* to use them, and I can't see how I'd get a better result using anything external.
Usual disclaimers apply, of course: Microchip's data sheets aren't exactly the most blindingly obvious texts I've ever seen, and my own ability to get the stick by the sticky end is not to be under-estimated, so there may be some way to improve this that I haven't seen, didn't understand, or simply missed on page four-hundred-and-twenty-whatever!
Tom
Post by: armdnrdy on January 16, 2014, 09:08:11 AM
Hey Tom,
The reason I'm inquiring about a higher clock rate is:
You are testing the MN3209 for a flanger effect and a MN3207 for a chorus effect.
There are designs which "overclock" and buffer a 1024 stage device to achieve a faster delay time better suited for flanging.
One reason this is done is because of the availability, or should I say the "non" availability of 256 stage and 512 stage BBDs in the market place.
There are a few companies that I am aware of that are producing BBDs which are made available to the DIY community.
These are Cool Audio, and Shanghai Belling. The BBD models are limited to equivalents of MN3205, MN3207, and MN3208.
Those three BBD models can be sourced from a small amount of reputable online merchants.
As far as the MN3209 goes....they are no longer in production, but "NOS" pieces can be sourced through sellers on ebay.
As we all know, purchasing BBDs from ebay can be a gamble as to whether or not you will be receiving the actual listed BBD or a relabeled, more commonly available model.
So you see the dilemma. A 500KHz clock can be limiting for certain designs.
I am a complete neophyte when it comes to PICs. Is it possible to manipulate the clock frequency with external components?
Post by: ElectricDruid on January 17, 2014, 09:09:23 AM
One other significant feature that I've done that I forgot to mention:
The Clock modulation is exponential in character, based on octaves. This means that if you use a normal triangle wave for the LFO, you get the same smooth effect you get using a hypertriangle on a normal flanger. The whole point of the hypertriangle waveform is to compensate for the linear clock modulation by applying an exponential function to the triangle waveform. So if you don't use linear modulation, but rather use exponential "V/Oct" modulation, you don't need to bother with hypertriangles to get an even sweep.
The typical linear clock modulation is also the reason why chorus effects get "warbley" as the depth increases when the delay time gets longer. If the LFO modulates the clock by +/-25KHz around a 200KHz centre point, that's only 12% or so variation. If it does the same around a 50KHz clock (lower clock frequency equals longer delay, remember) then that +/-25KHz shifts the pitch by 50%. Keeping the modulation in the exponential world of octaves removes this problem - half an octave of mod depth is still half an octave whether it's from 50KHz or 200KHz.
Thanks,
Tom
Post by: Mark Hammer on January 17, 2014, 09:39:58 AM
Neat!  Thoughtful!
Post by: 12Bass on January 18, 2014, 03:04:58 AM
Cool project!  Definitely curious to try this out when I get a chance.
Quote from: Mark Hammer on January 15, 2014, 03:07:39 PMSecond, what I witnessed was Mike Irwin's MN3007 adaptation of the A/DA flanger.  There was no discernible change in level as it swept to ever shorter delays.  Keep in mind that it is at the shortest delays that any flanger's worth is displayed.  If the BBD loses any substantial level at highest clock frequencies, then the intensity of the effect should suffer, as the dry/wet balance strays from a perfect 50/50 blend.  I didn't hear any of that.
Even a buffered SAD1024 loses about 1.5 dB as it sweeps up to the shortest delays.  My guess is that it is an unavoidable aspect of the technology (unless circuit gain is adjusted with clock frequency).  I've found that the ideal 50:50 ratio only exists for a moderate range of clock frequencies.  Go lower and gain increases slightly.  Go higher, and gain is reduced.  Another difference from the Panasonic BBDs is that the Reticon chip has considerably more extended high frequency response, which should help fidelity and make the cancellations more dramatic, as least if the filtering allows for it.
Post by: Fender3D on January 18, 2014, 11:12:25 AM
Quote from: 12Bass on January 18, 2014, 03:04:58 AM
Yep,
Tom if you have an extra pin left, please provide a voltage proportional to clock, so we can drive an OTA or a photoresistor and compensate for gain reduction...
Post by: ElectricDruid on January 18, 2014, 01:52:57 PM
Quote from: Fender3D on January 18, 2014, 11:12:25 AM
It's an interesting idea, but this is a digital chip, so probably the best you'd get would be a PWM output that you could filter to get a voltage proportional to the clock. And then you'd still have pass that voltage through some components that compensate for the particular gain curve of the BBD you're using. It gets a bit complicated, all to avoid a drop of a handful of dB at the far extreme end.
I suppose I could do that gain curve with a lookup table, but that'd assume that all BBDs are the same, or reasonably similar.
I'll think about it.
Post by: mth5044 on June 26, 2014, 02:51:20 PM
How's the project, Mr. Druid?
Post by: ElectricDruid on June 26, 2014, 05:22:08 PM
Well, it's timely that you ask, because after a break doing other stuff, it's actually back on my desk.
I want to sort out the feedback circuit, and add tap tempo to the software, and then I'll call it done. I haven't got enough pins to also include the up/down direction feature, so I either have to pick one and leave it, or I have to do more clever tricks to read two switches with one digital IO pin (not impossible - there are various techniques).
With the feedback, I wanted to have a centre-zero control with positive regen in one direction (CW I suppose) and negative regen in the other direction. That gives both options without needing a switch. The problem is that the maximum amount of signal before it runs away into oscillation isn't the same for positive as it it for negative, so it's hard to get the zero actually in the centre, at least without one of those special centre-tapped pots, but I'm staying away from rare parts like that.
So - that's the state of play.
Tom
Post by: mth5044 on June 26, 2014, 07:42:45 PM
Thanks for the update! Really cool project!
Post by: YouAre on November 13, 2014, 05:14:43 PM
A bit off topic, but do you think it's possible to create a new design that expands on the static delay to provide tap tempo for 3208/3205 Delay designs?
Post by: ElectricDruid on December 09, 2015, 07:42:46 AM
 :icon_exclaim:ZOMBIE THREAD ALERT: Please have favourite anti-zombie weapon handy:icon_exclaim:
It's taken a while, but I have actually finished this off, or at least got it to a point that other people can do something with it. There's (finally) code and schematics up on my website. I might have programmed chips and PCBs available in the new year.
http://electricdruid.net/flangelicious-a-super-dooper-flanger/ (http://electricdruid.net/flangelicious-a-super-dooper-flanger/)
The current code is a fairly experimental seven-waveforms-plus-manual-mode flanger. I might write a more conventional four-knob-flanger code and then do the programmed chips with that code, since I suspect that might be more popular than the current crazy soundscapes version. Opinions welcomed on this.
Thanks for reading!
Tom
Post by: dbp512 on December 09, 2015, 02:24:04 PM
Welp, this affirms the fact that I need to get a programmer. Once I'm done with exams I can get started, at least reading up on things and learning the language. As it is I have a growing list of circuits waiting for their turn under my iron, but this really piqued my interest.
Also, I wanted to build a dimension p, which is a dual chorus with pt2399's. I believe it accomplishes that by using a simple triangle wave and an inverting buffer for the second channel. It looks like with only minimal tweaking this chip could be used in that circuit as well.
Post by: samhay on December 09, 2015, 04:58:23 PM
Nice job Tom - well done on getting it finished(ish).
Is the 12F1501 brand new? It looks useful for this sort of thing.
Post by: ElectricDruid on December 09, 2015, 06:36:43 PM
Quote from: samhay on December 09, 2015, 04:58:23 PM
Hohoho! Thanks, I think. Getting the sweep as smooth as possible was the biggest difficulty. It might be digital, but I don't want to *hear* that it's digital.
Yeah, the 12F1501 is one of the newer "Enhanced" chips. The new NCO and CWG peripherals are what you need. The NCO acts as your BBD clock, and the CWG module is able to generate the biphase signal, even including a small deadband betwen the phases. So yes, definitely "useful" for this kind of thing. Pretty much ideal, actually. There are other chips that have the same peripherals, and I think there are some other 8-pin ones too, so it's not the only option.
Tom
Post by: armdnrdy on December 09, 2015, 07:24:34 PM
Cool stuff Tom!
Not a programmer myself so...I hope you find the time to add programmed chips to your collection of goodies.
Post by: alanp on December 10, 2015, 12:39:45 AM
That is a seriously clean flanger PCB. That would be perfect for a "first" flanger project for people still getting their feet wet with complicated projects and debugging them.
I noticed on your website --
QuoteOne problem is that the 8-pin chip only offers three analog-to-digital channels (CV inputs). This means that if you want to add a "Waveform" control, you have to drop the usual flanger "Manual" control.
Would it improve matters to use a PIC with more pins? I know nothing about PICs, other than they do all kinds of magic, and I have one or two FCUK Eurorack modules with your PIC magic.
Post by: ElectricDruid on December 10, 2015, 09:25:06 AM
Quote from: armdnrdy on December 09, 2015, 07:24:34 PM
Cool stuff Tom!
Thanks. The plan is definitely to do some programmed chips once I'm happy with the features.
Quote from: alanp on December 10, 2015, 12:39:45 AM
That's the general idea. Flangers are generally so complicated that the plan with this was to try and make a really simple one.
Yes, it would. I was trying to keep it down to an 8-pin chip, but that was just me trying to replace the MN3102. I've got a future plan for a 14-pin BBD clock chip that includes *all* the options. A bigger chip with more CV inputs and more program memory would make all sorts of things possible.
I'm thinking of a couple of simple 8-pin chips specialised for chorus and flanger, and then a 14-pin one with all the options and then some.
Post by: boogietone on December 11, 2015, 05:41:36 PM
Cool project.
Post by: boogietone on December 11, 2015, 07:03:33 PM
Where are you getting your bbd chips from?
Post by: greymedicine on December 12, 2015, 04:10:58 PM
How is the PIC able to create adequate clock voltage for the BBD? Is it because you're only running the BBD at 5V?
Post by: ElectricDruid on December 13, 2015, 06:56:16 PM
Quote from: greymedicine on December 12, 2015, 04:10:58 PM
Exactly! You could do it the other way, and boost the PIC's output to 9V, and run the BBD at the higher level, but it'd use more parts and makes things more complicated.
The reduced headroom isn't such a massive issue since BBDs don't let you use the full 9V anyway. Companding would help with noise levels, but that's always the case for flangers. I'm going to put a compander in the next flanger I do, the all-the-bells-and-whistles one.
Tom
