DIY Stompboxes => Building your own stompbox => Topic started by: alparent on September 25, 2014, 01:03:25 PM
Title: Need info - Peterman Stomp Puck
Post by: alparent on September 25, 2014, 01:03:25 PM
I'd like to make this: http://www.peterman.com.au/music/DIY/stomp-box-bass-transducer-pickup-student (http://www.peterman.com.au/music/DIY/stomp-box-bass-transducer-pickup-student)
Anybody as info that could help me?
Title: Re: Need info - Peterman Stomp Puck
Post by: R.G. on September 25, 2014, 02:25:46 PM
It's fairly obvious from the pictures. You find and trap a small, but good-bass-response speaker. Then you hook an 8-ohm to high-impedance baby transducer to it, and run that to the jack. Quality will depend on the qualities of the speaker, transformer, and the box you bolt it to.
A similar thing would have been made at one time by using a twin-T oscillator that was tuned to just not ...quite... oscillate so that any disturbance would make it ring. Low fundamental frequency gives a good bass thump. Suffers from not having proportional response to how hard you hit it, but mechanically much simpler.
Post by: alparent on September 25, 2014, 02:51:42 PM
I figured on of those 8-ohm to 1000-ohm I got from RadioShack would do the trick.
But if you look in is site, he talks about having some kind of weight on the speaker's cone. But I was not able to see it in any pictures.
That's the part I was hopping to get information on.
I admit the rest is pretty basic. I guess my question was not clear at all!  :icon_redface:
Post by: R.G. on September 25, 2014, 06:12:37 PM
Quote from: alparent on September 25, 2014, 02:51:42 PM
It was once a fairly well known trick in speaker building circles to lower the resonant frequency of a speaker by weighting the cone. The could be done a number of ways, but the simplest was to glue a circular weight very near the voice coil.
If I were doing this, I would be very tempted to glue a steel washer on the center/voice coil area of the speaker, and then to test it. You could easily enough add more weight with glue and whatever.
You'll probably use up a few speakers this way, but it's often possible to get 3-4" "mid bass" drivers cheap at some speaker places.
Post by: PRR on September 25, 2014, 11:41:06 PM
The classic cone-loading was:
modeling clay
solder
We didn't do steel because (on a Real speaker) it would be sucked up to the magnet (perhaps not on the weenie speaker).
Modeling clay is sure the way to start. When you get enough boom, peel the clay, weigh it, weigh out that much solder, coil it into the dome/cone valley, and glue.
Post by: alparent on September 26, 2014, 07:36:11 AM
Thank you guys.
This is great information.
Post by: R.G. on September 26, 2014, 09:37:15 AM
Quote from: PRR on September 25, 2014, 11:41:06 PM
Doh! Of course not steel. I wasn't thinking. I clearly need more coffee.
Do what Paul says - experiment with something like clay, load with something denser, but non magnetic.
I now return me to my coffee cup.    :)
