DIY Stompboxes => Building your own stompbox => Topic started by: aron on January 20, 2015, 08:44:21 PM
Title: Deluxe Memory Man Fixed
Post by: aron on January 20, 2015, 08:44:21 PM
Symptoms:
Horrid crackling when pedal touched/tapped.
Sometimes volume level would get 10X louder.
Obviously I knew something was loose but a cursory check showed nothing.
Isolated board from chassis and tapped both - only the board made noise so I knew it was something on the board.
Checked obvious solder pads and saw that the level pot solder was broken (was very difficult to see).
New solder and it works perfectly again. Sounds great!
Title: Re: Deluxe Memory Man Fixed
Post by: bloxstompboxes on January 20, 2015, 10:41:26 PM
Great job!
Post by: aron on January 21, 2015, 02:33:49 AM
Thanks. Just put it out there in case someone finds a Deluxe Memory man that is "broken". This is a great pedal.
