DIY Stompboxes => Building your own stompbox => Topic started by: Derringer on February 26, 2015, 04:58:22 PM
Title: OK, I give up. Can someone explain this bass boost and possibly a formula for it
Post by: Derringer on February 26, 2015, 04:58:22 PM
(http://i215.photobucket.com/albums/cc241/guyatron/active%20bass%20boost%20150Hz_zpsfnm3pzey.jpg)
this is nicked from ROG's new Thunderbird - Thank you B Tremblay
I tried my own research but just haven't had much luck finding what I want. In short, I have a fuzz on the breadboard and it sounds great. It sounds even better when I run an EQ after it and boost 100Hz a few Db's. So I though, hey why don't I try to make an active boost? I haven't done that before.
I want to use an opamp because half of that opamp is already being used as an input buffer. I found this gem and it's perfect ... says it's ready to go at 150Hz which should be fine.
But I'd love to know what it is and how it works please.
It looks a lot like the "Dual Version" of a "Twin T to Bridged-T Notch Filter" located at the bottom of R.G.'s essay on EQ's. http://www.geofex.com/article_folders/eqs/paramet.htm (http://www.geofex.com/article_folders/eqs/paramet.htm)
Thank you Mr. Keen.
But why does this version, the picture above, have two different caps? How does the pot affect the boost? Does this circuit also cut 150Hz?
Is there a nice math formula I could use to design something like this for other frequencies? Something I could put into a spreadsheet and make my own boxed up calculator for future use?
thanks!
edit- dangint ... yep, in my haste i left a connection out, thanks for the info guys
Title: Re: OK, I give up. Can someone explain this bass boost and possibly a formula for it
Post by: dschwartz on February 26, 2015, 09:09:30 PM
Something is missing there, the output should be connected to the feedback.
This is a very simple and effective peak filter, the net at the feedback is a T style notch filter, removing a range of freq. since it is at the feedback, the result is the opposite, boosting that range..
The caps are mismatched to give a lower Q on a broader range of freqs, you dont want a narrow boost, unless you want a wah type of sound..
The pot works as a "mix" control. At max, the signal fed to the inverting input is 100% passing thru the T filter, at min, the signal comes from the 47k resistor, where the filter is not effective..
I recommend you to learn how to simulate circuits..with ltSpice this would be easy to simulate and play with the values..
Post by: Mark Hammer on February 26, 2015, 09:29:03 PM
First, note that the .01uf cap and 47k resistor are also tied to the output of the op-amp.
It's a non-inverting op-amp configuration.  If there was to be any gain in such a circuit, there would need to be negative feedback from the output to the inverting input.  Do we have that?  Yes.  It can range from 47k, all the way up to 97k, depending on where the pot wiper is set.
Also, for gain, we would need a path to ground from the inverting output.  Do we have that?  Yes, via the 22k resistor.  It's weird, but it's there.
The gain of a non-inverting stage is determined by the feedback resistance, and ground-leg resistance, and their relative values.  Remember that an op-amp "wants" to function at open-loop gain of several thousand,  The negative feedback essentially "steps on the brakes" to arrive at gains less than MAX.  The more negative feedback, the lower the gain, and the more you bleed off or prevent negative feedback, the higher the gain.
Let's ignore the .01uf cap for the moment, and pretend as if we only have the two fixed resistors (47k, and 22k), the pot and the .15uf cap in there.  Look atthe schematic for a DOD250 or MXR Distortion+ and you'll see pretty much the same thing: a variable resistance on the ground leg, plus a fixed resistor (to set max gain) and a cap to block DC.  Unlike the DOD and MXR pedals, though, this pot is wired to reduce the ground-leg resistance at the same time as increasing the feedback resistance.
When the wiper is moved all the way to the .015uf cap, we have 97k feedback resistance, 22k ground leg, and .15u.  That yields a gain of 5.4x with a 6db/oct rolloff at 48hz.  If we rotate the pot the other way, so that the wiper is at the 47k resistor end, we have a feedback resistance of 47k, ground leg of 72k, and .15uf, giving a gain of  1.65x and a rolloff at 15hz.
BUT...we also have that .01uf cap.  And it plays a rather oddball role by sort of being in series with .15uf, and sort of providing a path to ground via the 22k, from the output.
And at this point, my expertise runs out.  TAG, somebody else is it.
Post by: Derringer on February 26, 2015, 10:06:25 PM
that definitely helps gentlemen, thank you.
LT Spice. Probably something I should look into when I have a moment or two. Good advice.
But a formula? It's got to be out there somewhere. Like what if I wanted 300Hz?
Is simming a circuit and trial and error playing with RC networks the best way to go?
Post by: merlinb on February 27, 2015, 06:51:44 AM
It's a bridged-T, often used to create a mid hump, although presumably in this case a bass hump.
The pot allows the feedback to be varied from the output of the bridged-T (max boost or humpiness) to a point only part way along the bridge, leading to less boost. If the 47k were shorted out then it would vary all the way from full boost to perfectly flat response...
(http://getlofi.com/wp-content/uploads/2010/03/ea_Bridged_T_Network.jpg)
Post by: PBE6 on February 27, 2015, 09:44:06 AM
The clever bit about this circuit is that by connecting the wiper to v- you keep the centre frequency constant as you boost. I've seen other implementations of this circuit (a proposed modification to ROG's Thor pedal actually, that replaced the 100k resistor in/out switch with a 100k pot) that connect the outer lug to v- instead. Same boost, but the frequency gets lower as you boost more. Both sound good.
The centre frequency formula for this type of circuit is:
Freq = 1/(2*pi*SQRT(Rf*Rg*C1*C2))
For more info see:
http://johnhearfield.com/RC/RC4.htm
Note: funny enough, swapping the resistors and capacitors gives you the same centre frequency but with different Q and gain characteristics.
Post by: Ripdivot on February 27, 2015, 11:20:03 AM
I calculate a freq of 89hz with the pot maxed and 127hz with the pot at minimum. How much gain does the circuit have in the two extreme positions of the pot and how does one calculate the gain in this setup?
Post by: midwayfair on February 27, 2015, 12:12:56 PM
Quote from: Ripdivot on February 27, 2015, 11:20:03 AM
Standard non-inverting op amp gain.
Gain is the resistance between the negative input and ground divided into the resistance between the negative input and the output pin, plus 1 (the plus 1 is the inherent unity gain of the non-inverting op amp).
You should be able to figure out the numbers on your own for any setting on the pot. Ignore the pot for a moment and assume it's 0Ohms between all lugs. (a) What's the resistance to ground directly from pin 2? (b) What's the resistance between pin 2 and pin 1? (c) Divide a into b, add 1, what's your gain? That's your baseline.
The pot's wiper is connected to pin 2, and it increases the resistance between pins 1 and 2 at the same time as it decreases the resistance between pin 2 and ground. Put it in the exact center so that it's 25K between the wiper and the other lugs, and repeat steps a-c above. What's your number this time?
If you turn the pot fully CCW, what are the resistances for a and b? Now recalculate steps a-c.
If you turn the pot full CW, what are the resistances for a and b? Now recalculate steps a-c.
Now you know the extremes. Want to find out what any particular setting on the pot is? As long as you end up with a total of 50K for the division between the wiper and the outside lugs of the pot, you can figure out the exact gain of any resistance.
Post by: PBE6 on February 27, 2015, 12:31:30 PM
Funny, I just ran a little simulation on CircuitLab and the centre frequency appears to be 89 Hz for the whole sweep of the pot. The max gain was about 14.2 dB, which is pretty close to the calculated gain:
Av = 1 + (47k + 50k)/22k = 5.409091
20*log(5.409091) = 14.7 dB
The minimum gain was 4.2 dB, quite a bit lower than I expected from a (probably incorrect) calculation:
Av = 1 + 47k/22k = 3.316364
20*log(3.316364) = 9.9 dB
I must be missing something obvious...
Post by: PBE6 on February 27, 2015, 12:39:22 PM
Aha! I think I found something. If you treat the remainder of the pot as a resistance in series with the ground resistor, you calculate something quite close to the low gain value:
Av = 1 + 47k/(50k + 22k) = 1.652778
20*log(1.652778 ) = 4.4 dB
Seems to work reasonably well for the midpoint on a linear pot too:
Av = 1 + (25k + 47k)/(25k + 22k) = 2.531915
20*log(2.531915) = 8.6 dB
The simulation has the gain as 7.9 dB, not right on but not far off. Will have to try it with other resistor values.
EDIT: (Didn't see midwayfair's post above)
Post by: Ripdivot on February 27, 2015, 01:33:12 PM
Quote from: PBE6 on February 27, 2015, 12:31:30 PM
You are correct, I miscalculated.
Post by: Derringer on February 27, 2015, 05:44:27 PM
SWEET ..... formulas and some in depth discussion. Thanks!
Quote from: Ripdivot on February 27, 2015, 01:33:12 PM
I'm getting the same values you did, 88 and 128. What were you calculating wrong?
When I tried adjusting the resistor values like PBE6 did for the gain calculations, my new frequency was about 70 ... which seems wrong
Post by: PBE6 on February 28, 2015, 02:44:08 AM
In the simulation, it appears that the frequency doesn't depend on the wiper position but only the total feedback loop resistance (47k + 50k) while the gain depends on the wiper position. This kinda makes sense for the filter, since current (ideally) only flows from Vout to ground through Rg (22k) so the filter is the same no matter where the wiper is set. It also kinda makes sense for the gain, since the opamp only cares about the feedback/ground resistance ratio. But it kinda doesn't make sense when thinking about them both at the same time, mostly because of the errors between the calculations and the simulation results (maybe due to neglecting the capacitors?)
Hats off to anyone trying to develop an algebraic expression for the transfer function, I found that I lost concentration after about 8 lines 😳 I will have to try it again with some coffee on hand...
Post by: bool on February 28, 2015, 04:54:20 AM
It will probably make it easier this way - or not: The EQ boost "action" will be in fact a reversal of a "notch" that a bridged-t circuit produces when used as an inline filter (the opamp will try to compensate for the "notch" in the NFB with a "boost" at the output). The boost added to the signal bacause of the non-inverting configuration (!) will be proportional to a pot-position, like it would be if it was a notch filter - but reversed as a boost.
Think in reversal, and apply in a given context.
Post by: Derringer on February 28, 2015, 09:00:55 AM
definitely understand the reversal "notch" concept ... good there, thank you
I'm with you on the wiper position concept too PBE6, both with regards to gain and the frequency calculation. Thanks!
So then the center frequency here is really about 89Hz and not 150Hz as advertized?
I have a spreadsheet to make  :icon_mrgreen:
Post by: jatalahd on February 28, 2015, 12:31:57 PM
Here is my two cents:
(http://guitarscience.net/complete.png)
I calculated the transfer function for the circuit as shown in the image above. When using the given transfer function, one needs to add the remaining part of the pot (noted as Rx) to R1, for example when pot is at "minimum", R1 = 47k + 50k and Rx = 1, when pot is at maximum, R1 = 47k and Rx = 50k.  When I plot the results in Octave I get the shown bandpass plot (for max, min and in between). When Rx is very small, I got a gain of 15 dB and when Rx is 50k the gain is about 4 dB at the center frequency of 89 Hz.
Theoretically, the center frequency f is actually shifted by the factor 1 + Rx/R1, but with these component values the center frequency stays the same 89 Hz, because the factor has a maximum value of 2 in this case and does not have much weight inside the square root. The quality factor can be calculated from here if someone has interest to it.
Hopefully someone had the same results from simulations? If so, then this transfer function is adequate to model the Bridged T op-amp circuit.
Post by: PBE6 on February 28, 2015, 01:19:38 PM
Nice work jatalahd! Very elegant. The simulation I ran on CircuitLab looks just like your calculated results.
Post by: Derringer on February 28, 2015, 03:39:51 PM
Quote from: PBE6 on February 28, 2015, 01:19:38 PM
+1
Post by: jatalahd on March 01, 2015, 03:38:39 AM
It looks like such a useful filter that I wanted to continue the calculations. Simplifications of earlier equations and evaluation of Q-factor lead to equations:
(http://www.guitarscience.net/new.png)
I have just rewritten the earlier equations into different form.
The obvious result is now that the mid-frequency is always constant and it just adds R1 and Rx as one resistance value.
The transfer function can be written in the form of non-inverting op-amp gain, 1 + Av. Now it is so clear that the gain function is a band-pass biquad function, whose gain is controlled with R1. Remember that I defined my analysis model so that Rx models the pot such that the remainder of Rx is added to R1. Therefore when the pot is at minimum (Rx is very small), R1 has the maximum value and gives the maximum gain.
I also calculated the Q. It is somewhat scaled by Rx/R2, which was a bit surprising. Using the given values, the maximum Q is 0.5 and minimum 0.16.
Then if someone wonders how the input filter (10uF and 47k) affects the results, I added the related scaling factor into the transfer function. When the product of Cin and Rin is kept large enough (condition given in image), it will not affect the transfer function at all. That is why I neglected it in the first place.
Before this I had never seen this kind of filter before, but it seems so amazingly useful that I really want to use it in many circuits! Thats also the reason I wanted to calculate and simplify the equations, because now in the simplified form they provide a much help to the design process.
Post by: PBE6 on March 01, 2015, 04:17:28 PM
+1 great work jatalahd, will definitely be referring to this many times for future builds!
Post by: bool on March 02, 2015, 07:09:35 AM
Quote from: jatalahd on March 01, 2015, 03:38:39 AM
I used T's since 80's - mostly as a predistortion boost, but with varied R2 (from your schem) which would in effect boost fe. low-mids differently than upper-mids when varied by user. I simply calculated the two extremes to fit within the what was deemed to be the "right" places to boost and then finally tweaked by ear to be ... well, "musical" in context.
Post by: stm on March 02, 2015, 07:28:48 AM
Quote from: Derringer on February 28, 2015, 09:00:55 AM
During the development of the Thunderbird circuit we started with the BOTTOM center frequency at 150 Hz and 15 dB of maximum boost, and so these values were propagated into the final write-up.  Nevertheless, the tone control filters were tweaked by ear afterwards until they sounded right.  We also found that going below 4.5 dB of bass boost was not necessary, so we split the 100k pot into a 50k pot and a 47k resistor so the entire BOTTOM control pot travel could be used.
Similarly, the TOP control is not centered at 3000 Hz anymore, and it does provide a bit more boost than 15 dB.  Guess it is time to update the write-up.
Post by: Derringer on March 02, 2015, 09:39:02 AM
cool
and you just answered another question for me as well, i think ...
I was wondering what would happen if I did just use a 100K pot instead of the 50K pot + 47K resistor.
The spreadsheet I made shows that it would essentially become a buffer if I used a 100K pot and rolled it down to 0R.
Is that in fact the case?
Looks like I may get a chance to finally breadboard this today.
something else too, with reference to jatalahd's equations and schematic ...
I find that if I swap the capacitor values and make C2 the larger cap, then the Q factor does not change as much as the pot is turned.
It ranges from 0.45 at minimum gain up to  0.51 at max gain.
But when C2 is the smaller cap, the Q factor ranges from 0.16 at minimum gain up to .51 at max gain
does that seem right? The center frequency seems the same. Granted though, I am using a simpler gain formula then Jatalahd is (I haven't found a nice way for Excel to compute imaginary numbers) so maybe the gains are affected when C2 is the larger cap somehow?
Post by: jatalahd on March 02, 2015, 12:02:48 PM
Quotemaybe the gains are affected when C2 is the larger cap somehow?
Yes, the gain is affected a great deal in that case, because the capacitor C1 has much larger reactance at the center frequency and cannot be neglected in the gain calculation. When C2 is the larger cap, the gain varies between 1 dB - 2 dB (min - max, pot rotation) and this also kind of explains the small variation in Q.
Post by: stm on March 02, 2015, 12:12:37 PM
Quote from: Derringer on March 02, 2015, 09:39:02 AM
cool
Exactly.  You can take a look at the Thunderbird TOP control for an example where the frequency response can vary from totally flat to a high peak around 6 kHz.
The order of the capacitors does indeed alter the Q factor, and yes, the Q factor diminishes as the peak amplitude is reduced.  This may not be desirable for a graphic equalizer, but luckily for us it works OK for guitar purposes :-)
If you are simplifying the formulas to avoid using imaginary numbers then the results are likely to be inaccurate.  I understand Excel can handle imaginary numbers, but last time I checked (Excel 2003) this was not part of the default installation, so you had to install/enable this capability first.
Post by: Derringer on March 02, 2015, 01:23:44 PM
ok then,
and 1 to 2 dB's may not be all of that much of a problem though if the larger Q factor sounds better
simple enough to swap a pair of caps on a board to hear what's what
(edit .. unless you meant that max gain may only be about 2dB's with the caps swapped)
from what I've been able to find out in excel, I can get a cell to have the value of "i" by inputting =COMPLEX(0,1)
but then it seems I need to have a different cell, or perhaps a much more complicate formula, where for every computation with a complex number I have to input a function that specifically tells the program that it will be adding, multiplying, or divideing a complex number etc etc
That degree just doesn't seem worth the effort right now when the simple gain calculation gets me in the ballpark.
however if I get a hold of mathlab or octave ... then let the games begin !
Post by: jatalahd on March 02, 2015, 02:10:44 PM
Quote(edit .. unless you meant that max gain may only be about 2dB's with the caps swapped)
Yes, this is what I meant, sorry for my bad English skills. First I was surprised that the gain would go that low, but I verified it by Spice simulation and indeed the max gain with caps swapped is 2 dB.
Post by: Derringer on March 02, 2015, 02:20:03 PM
No sir, your English is just fine. It's way better than my Finnish.
You did say the gain was "affected a great deal," which didn't sink into my brain until after I posted.
I just confirmed it for myself on the breadboard too.
Paljon kiitoksia
Post by: jatalahd on March 02, 2015, 03:21:48 PM
If you still want to get your spreadsheet completed, the Excel calculation is actually not that bad for the gain at the center frequency. In Excel I would suggest trying this (I tried it myself and got the correct result):
Cell D3 holds the value of the real part of the numerator:                 0
Cell E3 holds the value of the imaginary part of the numerator:       w*R1/( C2*R2*(R1 + Rx) )
Cell D4 holds the value of the real part of the denominator:             1/( C1*C2*R2*(R1+Rx) ) - w*w
Cell E4 holds the value of the imaginary part of the denominator:   w*( 1/C1 + (1/C2)*(1 + Rx/R2) )/(R1 + Rx)
In the above equations, you need to replace the component values (R1, R2, Rx, C1, C2) as references to the Excel Cells, where you have the values defined.
Also above, w = 2*PI()*f, where f is the center frequency 89 Hz. You can pre-calculate w into some other Cell and make a reference to it.
Then in Cell D6 write:   =IMDIV(COMPLEX(D3;E3);COMPLEX(D4;E4))
Then in Cell D7 write:   =20*log10(1 + IMABS(D6))
Finally, the value in D7 is the gain in dB
Post by: Derringer on March 03, 2015, 06:33:36 AM
Great! thank you.
What values were you getting then for the maximum gain of the circuit then? I'm getting about 9.4 dB's which seems low.
Post by: jatalahd on March 03, 2015, 11:36:42 AM
QuoteWhat values were you getting then for the maximum gain of the circuit then?
The Excel should give the same values as the Octave calculation, 14.208 dB max and 4.2955 dB min. Actually, when using the exact center angular frequency as w (instead of the very slightly rounded 89 Hz), all the real terms vanish from the quotient, and then the calculation could be done without using the complex() function. Anyway, here is a link to my "not so clear" .xls file, which should help you to get the correct values. I am still using the complex arithmetic in the Cell formulas, so it will give the correct gain value for any single frequency given as the angular frequency w.
http://www.guitarscience.net/gains.xls
You can change the value of "a" between 0.0 and 1.0 to simulate the turn-percentage of the pot. In the given spreadsheet I have now used the exact center frequency (real parts will be zero), and I also noticed I needed to make a small correction into the final formula giving the gain in dB in Cell D7. But you will notice the change from the file. I used Gnumeric in Linux to save the file in MS Excel format, hopefully it still works in Windows... I will remove the file from that download link after few weeks, since it is only there for special purpose in this case.
Post by: PBE6 on March 03, 2015, 12:51:41 PM
Hey!!! I bought your book! Fantastic resource with all the nitty gritty details, thanks for putting it together!
Post by: jatalahd on March 03, 2015, 02:23:13 PM
Quotenitty gritty details
As can be seen from this thread, I often get lost in the details :)
Post by: Derringer on March 03, 2015, 06:11:48 PM
Quote from: jatalahd on March 03, 2015, 02:23:13 PM
Is that like "Jazz Algebra?"  :icon_mrgreen:
Hey, thanks again for your help Jatalahd!
I downloaded your spreadsheet, replaced the gain calculation cell with your D7 value, then poked around and found the error in mine.
I have a separate cell where I can input R2. Then I have a cell next to it that shows the value of (R2) + (Pot resistance towards gain).
I had all the calculation cells referencing plain old R2 and not the sum of R2 and the variable pot resistance.
This spreadsheet is an awesome tool to have!
