DIY Stompboxes => Building your own stompbox => Topic started by: MusicalMan24 on April 10, 2015, 11:24:39 AM
Title: Help With Stutter Switch
Post by: MusicalMan24 on April 10, 2015, 11:24:39 AM
Is there anyway to have only two switches (one DPDT or 3DPT, and the other momentary) while still having the same function?
No toggle switches, only two foot switches.
As this is my first schematic/pedal please help anyway possible with improvements etc.
I'm a noob.  ;D
https://www.dropbox.com/s/yrqrq0hvtdzgvso/Stutter_Switch_V1.png?dl=0
Title: Re: Help With Stutter Switch
Post by: duck_arse on April 10, 2015, 12:06:26 PM
welcome, MM.
you're nearly there. is your momentary a "NO", "NC" or changeover? if it has an n/c and an n/o, it needs a common to connect between them. if it only has 2 lugs, I think yr drawn looks ok.
Post by: MusicalMan24 on April 10, 2015, 01:35:49 PM
Quote from: duck_arse on April 10, 2015, 12:06:26 PM
welcome, MM.
This is just an idea, I have no parts yet.
The schematic I drew has 3 switches, DPDT, NC momentary, NO momentary. The DPDT changes the line between the two switches.
I need help to somehow use two switches, one DPDT, and the other some kind of momentary.
Would either of these work?
http://smallbear-electronics.mybigcommerce.com/x-wing-momentary-dpdt/
http://smallbear-electronics.mybigcommerce.com/x-wing-momentary-spdt/
If so, how would It be wired?
Like I said, I'm a noob.  Thanks for your patience.  :icon_redface:
Post by: duck_arse on April 11, 2015, 11:02:33 AM
MM, have a look through this thread, I think it might clarify some of your thinkings:
http://www.diystompboxes.com/smfforum/index.php?topic=109554.0
and it'll save me some typings.
a double throw switch (DT) will have a normally open contact and a normally closed contact. you would only need one double pole switch to do what it is that you're confusing me with.
Post by: MusicalMan24 on April 11, 2015, 06:42:12 PM
Thank you, that's exactly what I needed.
I will hopefully build this in the next few weeks and post pictures.
