DIY Stompboxes => Building your own stompbox => Topic started by: Hemmel on January 05, 2017, 12:08:27 PM
Title: Ibanez TS808 footswitch repair
Post by: Hemmel on January 05, 2017, 12:08:27 PM
Hi guys.
I'd appreciate your advice on this.
My nephew has a TS808 that looks like this one:
(http://www.ibanez.co.jp/world/product_news/pages/2014/TS80835TH/images/ts80835thbg.png)
We tested it together and the footswitch doesn't work properly. Sometimes we need to press it 3 or 4 times for it to activate or deactivate the effect.
So I offered to replace the footswitch with a 3pdt, mainly because it's all I have, and I'd try to change it to a true bypass.
The goal is NOT to have a true bypass, it would be a "nice to have", but isn't necessary. As I said, the only reason I'm putting a 3pdt switch is because it's the only footswitch model I have in stock right now.
Inside of pedal looks very much like this:
(http://www.analogman.com/graphics/TS808-TL4558.jpg)
The current footswitch has only 2 wires, one going to connector #2 (on the picture, the 2nd from right, green wire) and another wire going to ground on output jack.
So this is what I thought of doing:
(https://s23.postimg.org/o83qfzq17/808_repair.png)
Advice? Questions? Comments?
Title: Re: Ibanez TS808 footswitch repair
Post by: bluebunny on January 05, 2017, 12:17:32 PM
Have you confirmed first that it's the switch that's at fault?  It should be making a reliable short across its lugs each time you press it.
Post by: Hemmel on January 05, 2017, 12:20:19 PM
I will double-check tonight.
During first test, after removing the switch from the circuit, both wires had continuity.
After pressing it, continuity was still there, and I had to press it hard, 3 times, before continuity broke.
Will reply tonight after more tests.
Post by: bluebunny on January 05, 2017, 12:57:52 PM
So the two wires that go to the switch are connected somehow, even without the switch connected to them?  Sounds like something amiss in the flip-flop circuitry.   ???
Post by: Hemmel on January 05, 2017, 01:12:13 PM
Actually, no.
I unsoldered the wires from the circuit board, not from the switch.
However, your reply has made me think that perhaps there is a bypass switching on the circuit board itself.
I'll have to find which version of the 808 this is, and find proper schematics.
Post by: bluebunny on January 05, 2017, 01:40:37 PM
I'm pretty sure that they're all the same (from a switching point of view).  But go to GeoFEX and check out the "Technology of the Tube Screamer (http://www.geofex.com/Article_Folders/TStech/tsxfram.htm)".  Either way, yes, the switching is on the board: a couple of transistors and some associated passives.
Post by: Hemmel on January 05, 2017, 02:28:59 PM
Thank for the link, Marc.... so after reading I realize it's a momentary switch, not an on-off switch like I thought it was.
This changes everything...
Also, after reading this post (http://www.diystompboxes.com/smfforum/index.php?topic=80168.0) I think a simple squirt of contact cleaner might do the trick.
I might have a small momentary switch laying around somewhere, I could use it to determine if the switching circuit is functional...
Post by: bluebunny on January 06, 2017, 03:15:00 AM
Quote from: Hemmel on January 05, 2017, 02:28:59 PM
You could test it simply by shorting across the switch lugs with a handy screwdriver or paper-clip or ...
Post by: Les Turnbull on January 06, 2017, 07:53:12 AM
Dont no if the 808 is similar to the TS9 but i replaced the spring under the foot switch on my TS9 and it now works 99% of the time though the TS9 are well known for there poor footswitching . The TS808 is back in production so a email to Ibanez may source a new switch .
Post by: Hemmel on February 07, 2017, 03:10:54 PM
Coming back to this... my nephew says he'd very much like a 3pdt stomp switch, mainly because all of his pedals have them, and that he's not used to the small switch on the 808.
Okay.
I found this guide:
https://web.archive.org/web/20120804013546/http://www.jackdeville.com/jackdeville/manuals/click-less_ibanez_ts808_install_manual.pdf
It seems quite straight-forward but it talks about having a "Click-Less True-Bypass PCB", which I obviously don't have.
So, I figured I'll simply use the 3pdt wiring scheme I'm used to, but then I'm a bit hesitant on a few things:
- Do I still remove the 56K resistor as suggested on page 3? I'm guessing it'll cut the JFET-switching part of the circuit, right?
- Looking at pages 6 and 7 I'm pretty sure I understand where to connect the 3pdt lugs but then on page 7 it talks about Switch 1 and 2 wires". I'm not sure what to do with them. Short them? Remove them?
Thanks again
EDIT: Okay. I found that the 56K resistor needs to be removed so that the JFET-switching circuit stays on "effect ON" mode, by preventing one of the JFETs from getting voltage. Got it.
Post by: Govmnt_Lacky on February 07, 2017, 03:40:39 PM
Keep in mind that most likely, the momentary flip-flop switching also controls power to the On/Off LED. Getting TB for the audio may just be as simple as removing and jumpering past a JFET (Q102?) but getting the LED to respond correctly may require replacement and wiring (with a CLR) to the new 3PDT switch.
Post by: Hemmel on February 07, 2017, 03:46:26 PM
Good call, G_L... hadn't thought of that...
TB?
Tuberculosis?
CLR?
(http://www.jelmar.com/images/2016/productclr.jpg)
Sorry, I'm not sure what those acronyms mean...
Post by: Govmnt_Lacky on February 07, 2017, 04:42:41 PM
Quote from: Hemmel on February 07, 2017, 03:46:26 PM
TB?
CLR?
TB = True Bypass
CLR = Current Limiting Resistor
Post by: Hemmel on February 07, 2017, 09:26:46 PM
Quote from: Govmnt_Lacky on February 07, 2017, 04:42:41 PM
TB = True Bypass
Yep. I feel stupid. Those were pretty obvious.
Well, I lifted the 56K, removed the old switch.
I'm going to try putting a 2K2 between the "LED-" wire and a lug of the 3pdt, just like most true-bypass (or TB ;) ) wiring.
Unfortunately, I've misplaced those 3pdt, so it'll have to go to tomorrow.
Post by: thermionix on February 08, 2017, 05:03:51 AM
I just did a 3PDT true bypass mod on a TS808 for a customer.  Just hours ago.  I was my first time and I had to figure it out with the factory schematic and layout.  But I nailed it and it works perfectly.  I can probably be of some help, it's all very fresh in my mind.
The LED part is easy.  Leave the two wires, red and pink, going to the LED daughter board.  The red wire is the +9v, and the pink goes to the CLR on the main board.  On the other side of the CLR is a zener diode, right near the middle of the main board.  Remove that zener diode.  In the hole where the cathode had been, add a wire, maybe 4 inches long.  That goes to the new footswitch to get connected to ground when the pedal is engaged.
I recommend wiring the new 3PDT to ground the input during bypass.  You can avoid switch pops without adding a pulldown.
Post by: Hemmel on February 08, 2017, 09:15:34 AM
Quote from: thermionix on February 08, 2017, 05:03:51 AM
Thank you for offering.
I'll try out what you said tonight and keep you posted.
Post by: thermionix on February 08, 2017, 05:06:36 PM
I grabbed these two images off a .pdf version of the original Ibanez service manual.  Tried to clean them up a bit.  The reissues are built exactly the same, came in very handy for me.
(http://i.imgur.com/Tl0r8ZV.png)
(http://i.imgur.com/L5wo4Qs.png)
Post by: Hemmel on February 15, 2017, 10:51:02 AM
It's hard to get free time to work on this.
Tonight, this is what I will attempt:
(http://i.imgur.com/8RX0pgq.jpg)
Fingers crossed!
Post by: thermionix on February 15, 2017, 10:01:50 PM
I also removed Q104, Q102 (replaced by jumper), R127, R117, R121, and C111.
I think your footswitch plan will work fine.
Post by: Hemmel on February 16, 2017, 10:23:05 AM
Well, yesterday I only had time to solder the jumpers on the 3pdt switch (pins 1-6 and 3-9).
I hope I wont be interrupted tonight.
Thermionix, can I ask why you removed all of those parts?
Post by: thermionix on February 16, 2017, 11:59:37 AM
Quote from: Hemmel on February 16, 2017, 10:23:05 AM
I didn't want any unused components touching the signal, and I didn't want any unused components drawing current from the battery.  I may have removed one or two more things than I needed to, but that way I was sure.  It worked, customer is happy, I'm happy.
Post by: Hemmel on February 16, 2017, 01:20:30 PM
Quote from: thermionix on February 16, 2017, 11:59:37 AM
That's actually a very good idea.
I'll try doing the same. Hopefully tonight.
Post by: Hemmel on February 17, 2017, 10:48:14 AM
Pedal is working.
Here's a quick recap:
Components removed:
- R126
- D107
Old momentary switch removed
- De-soldered both wires at the switch
- De-soldered live wire from pad 2 of PCB and re-soldered where cathode of D107 was. Other end of wire goes to pin 4 of 3PDT switch. This is to use the same current limiter resistor for the LED.
- Ground wire stayed on output jack sleeve, other end goes to pin 5 of 3PDT switch.
Adding 3PDT switch
- De-soldered wire from input jack tip and put it on pin 1 of 3PDT. Other end of wire stays on pad 11 of PCB.
- De-soldered wire from output jack tip and put it on pin 7 of 3PDT. Other end of wire stays on pad 1 of PCB.
- New wire from pin 2 of 3PDT to input jack tip.
- New wire from pin 8 of 3PDT to output jack tip.
- Jumpers between pins 1-6 and 3-9.
- Hole for momentary switch is a bit bigger than hole needed for 3PDT switch. Had to manage with 2 plastic washers to prevent 3PDT switch from moving.
Battery
- Old styrofoam used to protect switch from battery is now too big. Battery can fit snug between 3PDT switch and bottom of enclosure, but I need to find a way to isolate battery from switch with something very small.
- Battery door closes, but much tighter than before. The 3PDT switch takes up more space inside enclosure than the momentary switch.
Thanks to all who helped with this, especially thermionix.
I forgot to put back the plastic sheet that prevents the PCB from shorting on the metal bottom of the enclosure, so I have to open the pedal again. I'll try removing the additional components you mentioned.
Post by: thermionix on February 17, 2017, 01:50:47 PM
No problem!  It's not often that I can be of any help to people here, so I guess I kinda leapt at the chance.
I used one of the smaller-body switches...
http://smallbear-electronics.mybigcommerce.com/low-profile-3pdt-switch/ (http://smallbear-electronics.mybigcommerce.com/low-profile-3pdt-switch/)
...left a little more room for the battery.  But I think it still works out with the more "standard"-size 3PDTs.  I insulated the switch lugs with a cut out piece of the original foam, but I think the customer uses a power supply anyway.  I thought about gooping it with hot glue, but I wanted to make it so future switch replacement was relatively easy.  It might be ME that has to do it after all!
I desoldered D107 and Q102 because I had to solder in a wire and a jumper, but all the other components I removed were just snipped out.  Figured that was safest, because desoldering always includes some risk of damage to the PCB (lifting traces).  R121 was difficult to get to even with my small side cutters, other components in the way, so I probably would desolder that too if I had it to do again.
Porbably more detail than you need, but somebody might use this thread as a guide in the future, so just laying it all out there.
Post by: Hemmel on February 17, 2017, 03:48:57 PM
Quote from: thermionix on February 17, 2017, 01:50:47 PM
Same reason why I put everything I did.
For now I think I'll just leave everything as is since it's working. I'll just re-open the pedal to put back the plastic to prevent shorting the PCB.
