DIY Stompboxes => Building your own stompbox => Topic started by: haddocksknees on March 27, 2017, 01:02:17 PM
Title: Lovely Squeezer - Fuzzdog pedals - HELP!
Post by: haddocksknees on March 27, 2017, 01:02:17 PM
Hello there!
I'm not a complete noob, I've built quite a few projects but I'm not brilliant when it comes to debugging, I've not chucked anything in the bin yet but I'm very close with this one.
I've recently built a lovely squeezer compressor from http://shop.pedalparts.co.uk/ (http://shop.pedalparts.co.uk/) and I'm getting zero output, nada, zip.
Here's the link: http://pedalparts.co.uk/docs/LovelySqueezer.pdf (http://pedalparts.co.uk/docs/LovelySqueezer.pdf)
I've double checked diode polarity, electrolytic cap polarity, Pots etc and everything seemed ok, I also checked to see if there were any shorts and still everything seemed ok.
So I'm at a bit of a loss and need some help. So below is the schematic with a load of voltage readings which I hope are in the right place. Let me know if they're not, but any help would be appreciated.
Cheers folks!
(http://i64.tinypic.com/syb3fl.jpg)
Title: Re: Lovely Squeezer - Fuzzdog pedals - HELP!
Post by: Kipper4 on March 27, 2017, 01:18:31 PM
Edit RTFM Kipper
pins 1,2,3,5,6,7 of the Ic should all be around 4v6 seen at VB.
check your biasing resistors for bad joints R3 R7
Whats the voltages at pin 8 and 4 of the IC?
Post by: Cozybuilder on March 27, 2017, 01:36:53 PM
If you post photos of your build, front and back, one of us might spot something and give some useful insight.
Post by: haddocksknees on March 27, 2017, 07:07:28 PM
Thankyou both, Pin 8 reads 8.8v and pin 4 reads 0v
I'll post some photos tomorrow
Cheers again
Post by: haddocksknees on March 28, 2017, 12:39:30 PM
I decided to replace R7 and R3, and whilst I was at it I I thought I would try a different IC.
it only flippin' works!
Thanks for your help, appreciate it.
