DIY Stompboxes => Building your own stompbox => Topic started by: Plexi on April 30, 2017, 12:17:21 PM
Title: EQD The Depths
Post by: Plexi on April 30, 2017, 12:17:21 PM
Hi forum!
Anyone?
Schematic:
http://i.imgur.com/8R4keTO.png
http://1.bp.blogspot.com/-Zog3lZeCRD4/WHf_9OLLaCI/AAAAAAAAEgQ/zuHk_dgB_MYwJJsgP02cUjo6ZlhxkSejgCK4B/s1600/EQD%2BDepths.png
I finished it yesterday.
I do not know why, but it didn't work fine.
Sometimes led don't blink, and when it blinks, the effect is weak.
Due that I didn't find any MPS18, used sockets and tried every kind of NPN there.: MPSA13, 2N4401, BC548, 2N3904 ... but not MPSA18.
That's the problem?
Title: Re: EQD The Depths
Post by: GibsonGM on April 30, 2017, 12:34:14 PM
Dude - is there an actual schematic available?  Layouts don't tell a whole lot.
Not seeing any reason why your other tranny's wouldn't work the same as the MPSA18...
Post by: Plexi on April 30, 2017, 12:42:41 PM
My bad!
I thought I had put it on the first post.
Here it is!
Post by: GibsonGM on April 30, 2017, 02:18:44 PM
Ok, well - look in the LFO section around the transistors - the LED should blink reliably!  Something loose, etc....
As for weak - was there a specific LDR to be used? That can make a difference, if so.   How the "vactrols" were made (shrink tube?)...also, the depth ("intensity" here?) control might not be biasing the LED enough (?)
I'd 'fix' the LFO first, see if that helps!
Post by: Plexi on April 30, 2017, 06:26:13 PM
Thanks GibsonGM
I used 5mm ldr's, and red LED.
Didn't used shrink tube, just the four ldrs facing to the LED, and then black tape to avoid any light when I check for problems.
I noticed something, when plug in the sockets any transistor, at Q1, the LED start to blink very strong a few secs... then it stop, and start to blink weak.
Post by: ElectricDruid on April 30, 2017, 07:30:50 PM
Starts off blinking then stops blinking sounds like something charging up to me. I'd check all those electrolytic caps in the LFO section and make sure they're the right values and the right way around.
HTH,
Tom
Post by: Kipper4 on April 30, 2017, 08:14:51 PM
Without breadboarding the PSO it's hard to say for me if it would stall or not.
The PSO looks a bit weird to me. I feel sure though that EQD would have done their homework so as the others say check your connections. Non polar 1uf caps might help?
Post by: GibsonGM on May 01, 2017, 07:01:08 AM
Quote from: Plexi on April 30, 2017, 06:26:13 PM
Thanks GibsonGM
What the others said, re. performance of the LFO.
The depth issue may be how the LEDs are just 'facing' the LDR...might need to put them in a film can or find out if this is how the designer intended it.  Best results I've had have been 1 LED per LDR, inside shrink tubing, touching each other....but this depends on the design...
Post by: Kipper4 on May 01, 2017, 07:22:56 AM
^yep that.
Before now I've used an 8pin dip socket to mount the ldrs. (IIRC it was a 4 stage phaser)
So the led goes down the centre cavity of the dip socket.
the 4x ldr's each have a leg in the sockets. (soldered in)
Then I've heat shunk wrapped the whole thing with some wide shrink.
It depends on the application and layout.
I've also done dual LDR ,single led vactrols    just on the pcb No heatshrink.
It's confined in the box after all. you might have to consider the effects of a bypass indicator led shining back in the box though.
Maybe use black epoxy or silicone sealant or a sharpie to dull the underside inside the box.
Needs must.
Post by: ElectricDruid on May 01, 2017, 08:10:10 AM
The on/off resistance of your LDR is going to have an effect here too, and that's by no means the same between LDRs. In this circuit it'll shift the frequency of the phaser notch, and it could easily shift it to somewhere you won't hear it much (sub-bass, or high treble) if the resistance isn't right. You might need to adjust the related capacitor value to compensate.
HTH,
Tom
Post by: duck_arse on May 01, 2017, 11:21:18 AM
this suggests to me that one leg of the pso is not grounded right, or has too high a resistance to ground. check very carefully the resistances to ground from C8//C9 and C8//C12. try turning the rate pot to one extreme or the other before powering on. once the osc "dies", turn the pot all the way opposite, see if it starts up again (gradually).
make sure your dual-pot connections are sane, they should both sweep higher/lower resistance together, not opposite. changing the 1uF caps for polys might also help.
I also think that circuit is drawn wrong, because the rate pots will go to 0R across the phase-shift network, stopping the osc EVERY TIME. that's if I'm reading the dia right. the pots should have a stop resistor between them and ground (the 3k3 would suffice), and that string should be parallel across the 220k's slung between the caps and ground. see R.G.'s univibe oscillator diagrams.
Post by: Plexi on May 01, 2017, 07:03:06 PM
Thanks guys for all your help...!
That's why I love this forum
As soon I get back home, I'll check all your suggestions.
Thanks again
Post by: Plexi on May 04, 2017, 12:15:49 PM
Ok, here's some update.
First of all, I would like to say that I'm checking carefully every advise you guys suggest (thanks a lot).
I swapped the transistors for the most closest hfe to MPSA18 that I have: BC109 and 2N2907, and it works better in many ways.
Still haven't the regular working, and rarelly stopped.
I'll keep working on.
Thanks again!
Post by: sominka on May 04, 2017, 04:48:47 PM
Please note. The 150n cap on the layout should actually be 15n which is what is shown on the schematic. I finished building this a couple of days ago using the layout from the perf and pcb layouts  site and it works really good.
I used a 10mm red led and bent the LDR's to face it after soldering them in position. LDR's were just some random ones I had in stock but measured roughly 1K in the room light I was working in.
MPSA18 for the transistors and check you have all the jumper leads in place on the board if using the pcb layout.
Hope this might help.
Post by: thehallofshields on November 12, 2018, 01:24:50 PM
Is this thing any different from a standard Phase Shifter?
Post by: ElectricDruid on November 12, 2018, 03:25:49 PM
Quote from: thehallofshields on November 12, 2018, 01:24:50 PM
No, not really. It's the standard phase stage circuit, done with LDRs as the variable element, as many others have been. Some use FETs in this same position. It's about as standard as it gets, TBH.
Edit: I don't mean that to sound like a criticism. Just to be clear, some of the reasons that circuit is widespread is because it's simple, reliable, and does the job well. But it's not winning awards for originality any more!
Post by: pinkjimiphoton on December 04, 2018, 10:15:18 PM
i love this circuit, i swapped out my dunlop univibe for it. aisha built mine for me as a gift a couple years ago, used a 3mm green led and bog standard ldr's. works great. led in the middle, and ldrs around it like a univibe.
i am pretty sure you don't want the ldrs against the leds like a vactrol. it needs a little room for the led to fade.
now... from your problem and description, one of the pots should make the led brighter as ya turn it up... any chance a pot is wired backwards, plexi?
Post by: thehallofshields on December 07, 2018, 03:10:11 AM
Quote from: ElectricDruid on November 12, 2018, 03:25:49 PM
What's the advantage of LDR in this case? More linear response than FET?
Post by: Mark Hammer on December 07, 2018, 12:37:33 PM
FETs can distort.  Some phasers use a network around the FET to raise the clipping threshold, though they do not render the FET immune from clipping.  LDRs, on the other hand HAVE no clipping threshold.  They are, after all, simply resistors.  One of the things that allows is goosing the input level of the circuit such that a better S/N ratio can be obtained.
Additionally, many LDRs have a little bit of lag in them (or at least can selected for that property), as they adjust to the onset and offset of illumination.  That lag introduces a certain distinctive shape to the modulation sweep, that can sound more "musical" to many ears.  When it comes to modulation pedals, I find a lot is riding on "the turnaround", when the sweep gets out to the end-point and begins in the other direction again.  Another part of that is also the lag introduced by the warm-up and cool-down time of incandescent bulb filaments, that also changes the shape of the modulation sweep.
Sometimes, a little bit of sluggishness is a good thing.
Post by: PRR on December 07, 2018, 11:54:43 PM
They are terrible resistors. Run fine music at 3V across one, you will hear it. (I used some as last-gasp protection for Crown D-150s.)
Yes, at the sub-Volt levels in guitar chain they are inoffensive.
Post by: FlyingWild on February 16, 2019, 01:29:09 PM
I'm keen to give this one ago, and have been working on the PCB layout over the last couple of evenings. In my research I came across a post on another site: http://tagboardeffects.blogspot.com/2016/11/earthquaker-devices-dephs.html?showComment=1507864550656#c4218660811678748540 (http://tagboardeffects.blogspot.com/2016/11/earthquaker-devices-dephs.html?showComment=1507864550656#c4218660811678748540) advocating putting a trimmer pot in place of the 47k resistor that connects the Base & Collector of the MPSA18 to the LED. R25 in my schematic:
(https://i.postimg.cc/Ny2Xr3Rj/Depths.jpg) (https://postimg.cc/Ny2Xr3Rj)
Luckily I've not run out of room, so I can put one in, but what I've not discovered, now that it's variable feast, is how do I know when I've set it correctly? I'm not sure I understand what it's doing and I would be really grateful if anyone could tell me.
Also, the suggested trim pot value is 250k which is replacing a 47k resistor, would 100k seem more sensible?
Post by: bms19 on November 27, 2023, 01:42:49 PM
I came after the battle I see. Yes I do have problems with the LFO as well, stop working at low settings. Any idea how to correct that?
Benoit
Post by: Plexi on March 15, 2024, 10:49:05 AM
Quote from: bms19 on November 27, 2023, 01:42:49 PMI came after the battle I see. Yes I do have problems with the LFO as well, stop working at low settings. Any idea how to correct that?
Benoit
Whar are you using over Q1 and Q2? which voltajes are there?
Post by: Steben on April 20, 2024, 06:01:10 AM
Hi guys. I bought a depths clone pedal recently. Same issue with lfo...
