DIY Stompboxes => Building your own stompbox => Topic started by: cannedwalrus on December 08, 2017, 11:01:41 PM
Title: Am I on the right track with this triple tap tempo?
Post by: cannedwalrus on December 08, 2017, 11:01:41 PM
Looking to build a tap tempo that syncs 3 Normally Open pedals at once. The third one is a Strymon which I hear need a TRS to work. Am I on the right track here?
(https://s18.postimg.org/ipp9ku5ut/EF03_EE20-9_C7_B-478_F-_BB46-2672_DA1_B3438.jpg) (https://postimg.org/image/ipp9ku5ut/)
Title: Re: Am I on the right track with this triple tap tempo?
Post by: blackieNYC on December 09, 2017, 06:13:00 PM
I don't think so.  Have you drawn audio paths there? Or tap tempo control lines?  Not sure what you have going on there. One tap tempo controller could be made to control several devices - each device will have to be made to accept this control signal.
Post by: cannedwalrus on December 09, 2017, 06:24:06 PM
Quote from: blackieNYC on December 09, 2017, 06:13:00 PM
I don't think you understood my post. It's an external tap tempo for delays/modulations that have external tap jacks. I wired up a prototype today and it did work, the only tweak I had to make was that the tip on the stereo jack had to be wired to the center lug on the 3PDT switch because the Strymon pedals require an external tap to switch the tip between the ring and the sleeve.
Post by: blackieNYC on December 10, 2017, 12:15:46 AM
Ah. I see.
Your drawing has the sleeve switching between tip and ring. Strymon wants the tip to go to sleeve (ground) or ring (+5v).  Figure out which connection, 5v or gnd to tip, is the trigger.
