DIY Stompboxes => Building your own stompbox => Topic started by: Harry Muff on September 14, 2020, 10:39:06 PM
Title: 4 pole 5 way double wafer
Post by: Harry Muff on September 14, 2020, 10:39:06 PM
opened up my brand new strat to give it a new tone cap and pots - never seen a large switch like this before ..not sure im
going to be able to wire it up like I wanted lol
also my fender humbucker has 60 cycle hum like its broken ..i noticed the white wire is grounded and the black wire is on the double wafer
if im not mistaken without googling I thought red/white were soldered and taped off to dangle leaving hot green to lug and black/open ground wire to ground?
is that wired for split coil ? its very noisy for a humbucker !!
(https://i.postimg.cc/DmZyptLR/IMG-0051.jpg) (https://postimg.cc/DmZyptLR)
Title: Re: 4 pole 5 way double wafer
Post by: GGBB on September 16, 2020, 06:57:24 PM
HSS Player Strat? The bridge+middle position splits the humbucker so you get real single-coil quack. According to Fender wiring is:
Postion 1. Bridge Humbucking Pickup;
Position 2. Middle Pickup and Inner Coil of Humbucker;
Position 3. Middle Pickup;
Position 4. Neck and Middle Pickup;
Position 5. Neck Pickup
https://www.fmicassets.com/Damroot/Original/10001/SM_014452XXXX_Player_Strat_HSS_Rev_A.pdf
Post by: Harry Muff on September 17, 2020, 03:02:06 AM
pos 1 is not working properly ..its stripped apart now , im going to do an old school wiring from SD website ..i should of sent back but im happy with the amount of flame and dont want to chance a lesser flamed model.  yes its a hss blue burst
