DIY Stompboxes => Building your own stompbox => Topic started by: matmosphere on January 27, 2022, 04:05:55 PM
Title: Anything use the LM308 that isn't based on the Rat?
Post by: matmosphere on January 27, 2022, 04:05:55 PM
Just curious if anyone has seen a non-rat based circuit that uses the LM308. I figure it would have to be from the seventies or eighties because the 308 hasn't been made in forever.
Title: Re: Anything use the LM308 that isn't based on the Rat?
Post by: vigilante397 on January 27, 2022, 04:33:51 PM
I'm certainly not aware of anything, though I'm also curious. LM308 and Rat are so intertwined, it's hard to imagine either one without the other.
Post by: iainpunk on January 27, 2022, 05:36:39 PM
I have some vague memories of a really expensive overdrive pedal advertising the use of the venerable 308, i cant recall builder/brand tho. Iirc it was based on a TS808 with the clipping opamp a 308 and the tone control another type.
Cheers
Post by: John Lyons on January 27, 2022, 07:47:00 PM
Bixonic Expandora (original version)?
Post by: mozz on January 27, 2022, 08:13:22 PM
Peavey hotfoot. Jk. Opps, it's a rat inside.
Post by: matmosphere on January 28, 2022, 03:44:42 AM
Quote from: John Lyons on January 27, 2022, 07:47:00 PM
I thought that was just a modded Rat. I'll take a look
Post by: Elektrojänis on January 28, 2022, 05:02:38 AM
Then again... If you only look at the clipping gainstage, how far can you get from the rat in an opamp based distortion?
Differences seem to be mostly tone shaping from different part values and how the gain control is configured.
Even if you look at overdrives, they are very similar... Only the clipping diodes are placed in to the feedback loop instead of from output to ground. The topology is still very similar.
Post by: sergiomr706 on January 28, 2022, 07:30:25 AM
Paia Gator maybe?
Post by: D_Ex_Patria on January 28, 2022, 09:01:39 AM
A few of Roger Mayer's op-amp based fuzzes use 308s, like the Mongoose, Voodoo, and Spitfire. Most of those schematics are a fairly easy google.
