DIY Stompboxes => Building your own stompbox => Topic started by: fryingpan on July 28, 2023, 12:03:25 PM
Title: Two-stage all-pass vibrato circuits, Tri-Vibe (RunOffGroove) and ESP v2
Post by: fryingpan on July 28, 2023, 12:03:25 PM
The Tri-Vibe is a nice OTA design, with maybe weak vibrato but a very nice rotary speaker effect. The ESP design uses LDRs instead (so much higher headroom, slower maximum rate though) and instead of having the three modes, it has an "effect" potentiometer mixing the clean signal with the wet signal. What is the difference in implementation between the two? (Meaning, the three modes as opposed to the mix control). The Tri-Vibe goes from no dry signal (Vibrato), to a 47k series resistor on the dry signal path when in Whirl/Phaser mode (so a 1:1 ratio between wet and dry) and a 100k resistor in Swirl/Rotary mode (so a 2:1 ratio). AFAICT, this could be replaced with, say, one of those pots with bypass at minimum (you know, when it "clicks"), of an appropriate value of course, with the same end result, right? Also, one could double the phaser stages to have a stronger vibrato effect?
Title: Re: Two-stage all-pass vibrato circuits, Tri-Vibe (RunOffGroove) and ESP v2
Post by: fryingpan on July 28, 2023, 02:36:27 PM
Here are the two schematics:
http://www.runoffgroove.com/tri-vibe.png
https://sound-au.com/p206-f1.gif
modulator circuit for ESP V2:
https://sound-au.com/p206-f2.gif
Post by: ElectricDruid on July 29, 2023, 05:29:49 AM
Quote from: fryingpan on July 28, 2023, 12:03:25 PM
I think you've spotted all the differences already, tbh. As you've pointed out:
1) Phase shift stages based on OTAs vs LDRs
2) Different approach to mixing wet/dry signals (passive crossfade vs active mixer)
3) Different LFO design, only partly driven by necessarily different drive of OTAs vs LEDs.
These three modes are pretty tidy, I reckon. It covers the basic stuff you might want without bogging things down in more options. Note that the equivalent positions on the ESP design are all in one-half of the pot's rotation. There's no equivalent on the Trivibe to the mostly-dry settings you can get on the ESP.
Yep, lots of ways this could be done. Classic wet/dry mixer, as shown here, is another:
https://electricdruid.net/two-stomplfo-projects-ptwobble/ (https://electricdruid.net/two-stomplfo-projects-ptwobble/)
Yes, why not? "Noise" is the only reason - it'll build up the more stages you add, which is particularly an issue with the low signal levels in the OTA design.
HTH
